Time taken for two substances to reach equilibrium (equation?)
  • Thread starter Thread starter Da Apprentice
    Equilibrium Time
The discussion centers on the time taken for two substances to reach thermal equilibrium, specifically in the context of an experiment involving beakers at different temperatures. The experiment demonstrated that a beaker at 25°C inside another at 100°C took 7 minutes to equilibrate. The participant questioned whether reducing the inner beaker's volume to 1/4 of the outer beaker would halve the time to reach equilibrium. Additionally, the time constant for a simple A <-> B chemical reaction is confirmed as 1/(k1 + k2), where k1 is the forward rate constant and k2 is the reverse rate constant.
  • Understanding of thermal equilibrium principles
  • Familiarity with chemical reaction kinetics
  • Knowledge of rate constants in chemical reactions
  • Basic grasp of experimental design in physics
  • Research the impact of volume ratios on thermal equilibrium time
  • Study the derivation and application of the time constant in chemical kinetics
  • Explore the Arrhenius equation and its relation to reaction rates
  • Investigate heat transfer methods in thermodynamics
This discussion is beneficial for physics students, chemists, and researchers interested in thermal dynamics and chemical reaction kinetics.
Da Apprentice
I was wondering is there a formula that relates to the time it takes for a system to reach equilibrium? For example in an experiment I used one beaker at 25C inside another at 100C. The volume of the inner beakers was 1/2 that of the outer and with this combiation it took 7minutes for both beakers to reach the same temperature. If the volume of the inner beaker were changed to 1/4 of the outer beaker (starting at the same temperatures) would it take half the time to reach equilibrium as the previous example?
Chemistry news on Phys.org
This is more of a physics question. For a simple A <-> B chemical reaction with forward rate k1 and reverse rate constant k2 the time constant for reaching equlibrium is 1/(k1 + k2) if I remember correctly.
The time constant how is this then used? Forward and Reverse rate - are these the rates at which the equation takes to reach equilibrium? e.g. Graph attached?
EDIT: Ignore the writing at the bottom of the graph - I know it's a pointless statement
