What Is Rutherford's Gold Leaf Experiment?
  • Context: High School
  • Thread starter Thread starter Demiwing
    Gold
The discussion centers around Rutherford's Gold Leaf Experiment, exploring its methodology, implications, and historical significance in atomic physics. Participants seek clarification on the experiment's details and its scientific context.
  • One participant expresses a lack of clarity about the experiment and invites collaboration for better understanding.
  • Another participant summarizes that Rutherford's experiment involved bombarding gold foil with alpha particles, demonstrating that atomic nuclei are small and that atoms consist mostly of empty space, challenging the plum pudding model.
  • A participant mentions the contributions of Bohr in developing the planetary model of the atom and highlights the historical context of discoveries related to the nucleus and electrons.
  • One participant explains that the gold foil allows most alpha particles to pass through, but some are scattered at large angles due to close encounters with gold nuclei, likening the result to firing a cannonball at tissue paper.
  • A participant introduces the Gold Leaf Electroscope as an early instrument for measuring gas ionization rates, describing its operation with a radioactive source.
  • Several participants request a more scientific explanation of the experiment and its components.
Participants express varying levels of understanding and interest in the scientific details of the experiment. There is no consensus on a single explanation or model, and multiple perspectives on the experiment's significance are presented.
Some participants seek more rigorous scientific explanations, indicating that the discussion may lack depth in technical details and formal definitions.
Demiwing
anyone familiar with this? Rutherford (Ernest) had a famous experiment with the gold leaf and some radiactive source. Anyone want to calloborate? Becuz i m not so clear on wat that is
You might try an atomic or nuclear physics book. Simply stated, by bombarding the foil with alpha particles, Rutherford demonstrated that nucleii are very small, and that atoms are mostly space. The so called plum pudding model was disproved.
Bohr, who worked with Rutherford, saved the idea of a "planatary model" of the atom, with the astonishing idea of quantum stability, and derived the formulas of the hydrogen spectra to substantial accuracy. Rutherford discovered the nucleus, Thompson discovered the electron, and Bohr gave the first successful theory of the atom based on electrons and nucleii.
Regards
Reilly Atkinson
Regards
Reilly Atkinson
thanks, do u know how the alpha particles and the goldfoil work?
The gold foil let's most alpha particles through, because the gold atoms aren't too close together. But occasionally an alpha particle comes close enough to a gold nucleus to be scattered. Some of them are scattered through very large angles.
Rutherford's famous statement was that the result of the experiment was like firing a cannon ball at a piece of tissue paper and having it come back and hit you.
It was one of the first and simplest instruments used to determine the rate of ionization of gases. Charge the leafs so they separate by some angle. Then use a radioactive source to inonize the gas in the leafs container. The rate at which the leafs angle decreases is proportional to the rate of gas ionization.
Regards
Don
i want it more scientifically
  • · Replies 0 ·
  • · Replies 49 ·
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 24 ·
