Why does a capacitor prevent the spark?
  • Context: Undergrad
  • Thread starter Thread starter arcnets
    Capacitor Spark
The discussion centers around the question of why a capacitor can prevent a spark when closing an electrical switch. Participants explore the theoretical and practical implications of using capacitors in this context, addressing both AC and DC circuits.
  • Some participants suggest that capacitors force voltage changes to be continuous, preventing instantaneous voltage changes that could cause a spark.
  • Others argue that the effectiveness of a capacitor in preventing a spark depends on its arrangement relative to the switch, particularly in terms of charge time and connection.
  • One participant questions whether a charged capacitor would still produce a spark when shorted, indicating uncertainty about Feynman's assertion.
  • Another viewpoint emphasizes that a capacitor placed parallel to the switch can provide an alternate current path for transient currents, potentially preventing arcing by allowing current to flow before the switch contacts close.
  • Some participants note that while this method may work in AC circuits, it may not be effective in DC circuits, where the capacitor could become fully charged and not prevent sparking.
  • A later reply discusses the concept of capacitance in relation to the switch contacts, suggesting that the rapid increase in capacitance as the switch closes could lead to a current surge and spark, unless mitigated by the parallel capacitor.
Participants express differing views on the effectiveness of capacitors in preventing sparks, particularly distinguishing between AC and DC circuits. There is no consensus on the best approach or model to explain the phenomenon.
Participants highlight various assumptions regarding circuit configurations, charge states of capacitors, and the nature of current flow, which may affect the outcomes discussed.
arcnets
I read this in Feynman's book 'Surely you are joking Mr.Feynman' but I didn't understand it.
'If you close an electrical switch, there will be a spark shortly before the contact is made. If you don't want any spark, just put a capacitor across the switch.'
My question: Why does a capacitor prevent the spark? There's still the same voltage on the switch, isn't it?
Capacitors force voltage changes to be continuous -- in other words, they ensure that the voltage won't go from 0V to +V instantaneously. The capacitor will have to charge from 0V to +V, which will take a period of time.
- Warren
I don't think this helps for closing a switch unless it is arranged so that the capacitor is linked to the switch. For example, a capacitor with a long charge time is rigged so that it bridges the switch just before the switch is closed.
Njorl
chroot - I think the capacitor is already charged before you close the switch. And if you short a charged capacitor, there will be a spark won't it?
Njorl - do you think Feynman is wrong here?
I have "Surely you must be joking..." at home. What page is it on? I'm not about to say Feynman's wrong lightly. Then again, he'd turn over in his grave if I didn't accept the possibility.
Njorl
If a cap is placed parallel to the switch contacts, it will create a alternate current path for transient currents. Rather than jumping the closing gap of the switch contacts, current will take the path of least resistance into the capasitor.
Consider that the cap will charge to circiut voltage while the switch is open, this provides a source of mobile electrons that are able to redistribute as the EM field changes around the closing switch contacts, essentially this will allow circiut current to flow BEFORE the switch contacts actually close. Thus eliminating any chance of a spark.
Such capasitors are in common use in such places as old fashioned auto distributors (across the points) and in nearly every high voltage contactor circiut.
Modern Solid State Relays (SSR) avoid this propblem in AC voltage switching by changing state only at a AC zero Volts crossing. So the switch changes state the circiut voltage is O, thus no arc is possible.
Thanks! I understand now.
For a DC circuit, this just isn't going to work. The cap gets fully charged. For the transient pulse to go to the capacitor, it would be overcharging it, not discharging it. The electrons won't go that way.
Think of this. Charge a capacitor. Remove it from the charger. Put a switch across the contacts. Close the switch. You get a spark. By putting the cap across the switch of a DC circuit, you probably are making things worse.
It would work for an AC circuit, but the capacitor would have to be small, so as not to be an AC short.
Njorl
OK, let's consider this.
Why does a switch arc? Essentially it can be treated as a capacitor with the contacts as the plate. When the contacts are far apart there is a very small capacitance, but as the switch closes the capacitance increases rapidly causing a significant change in the amount of charge stored in the "plates" this current surge is the source of the spark.
Now put in a parallel capacitor, since capacitance of contacts will be small in comparance to that of the capacitor it will make a very small contribution to the total capacitance. (Recall that caps in parallel add as series resistors) now when the switch is open the cap, including the switch contacts will charge to circiut voltage. As the switch closes there will be only a small increase in TOTAL capacistance so therefore a small surge current (if any). Thus no arc.
I think that an isolated charged capacitor should not be used as a model for this situation, here we have other circiutry which limits the total current flow, that is not true when a cap is shorted.
  • · Replies 61 ·
14K
