Register to reply
Angular Momentum/Impulse Problem
by cdbowman42
Tags: angular momentum
Share this thread:
cdbowman42
#1
Apr21-11, 04:18 PM
P: 14
[b]1. A 1.8 kg, 20 cm diameter turntable rotates at 160 rpm on frictionless bearings. Two 500 g blocks fall from above, hit the turntable simultaneously at opposite ends of a diagonal, and stick. What is the turntable's angular velocity, in rpm, just after this event?
[b]2. Angular momentum(L)=angular velocity(w)*moment of inertia(I)
[b]3. I'm confused as to whether or not to appraoch this as a conservation of momentum problem or some other way. I think I would need to know the velocities of the blocks before they hit to to this.
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
olivermsun
#2
Apr21-11, 04:21 PM
P: 785
Do the blocks carry with them any angular momentum of their own? (It seems the problem is set up to hint that they do not).
cdbowman42
#3
Apr21-11, 04:22 PM
P: 14
Thanks! thats all I needed!
tiny-tim
#4
Apr21-11, 04:23 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
hi cdbowman42!
Quote Quote by cdbowman42 View Post
hint: what was their angular momentum about the axis, before they hit?
(assuming they fell vertically at speed v)
AlexChandler
#5
Apr21-11, 05:04 PM
AlexChandler's Avatar
P: 283
I would think about it in the following way
[tex] \int \tau dt = \Delta ( I \omega) [/tex]
where [tex] \int \tau dt [/tex] is the angular impulse and [tex] \Delta (I \omega) [/tex] is the change in angular momentum.
We can see that no vertical torque is exerted on the turntable, so the angular momentum must remain constant.
Then we must have
[tex] (I \omega)_{initial} = (I \omega)_{final} [/tex]
Register to reply
Related Discussions
Angular impulse problem Introductory Physics Homework 0
Angular Impulse and Angular Momentum Introductory Physics Homework 2
Angular momentum - impulse on the axis Introductory Physics Homework 9
Angular impulse and angular momentum questions Introductory Physics Homework 7
Impulse/momentum problem Introductory Physics Homework 4
