| New Reply |
Power ratings on battery |
Share Thread | Thread Tools |
| Apr22-11, 05:02 PM | #1 |
So I've been trying to work on this project that requires me to take a 12V AC to DC adapter (says 300mA on it) and supply power to a CPU fan (11.8V, 0.57A) and several LEDS (20mA forward current, 3.2V). My question is what does the 300mA exactly mean as I thought that there was no such thing as a current source.
Also, I connected my CPU fan to a 9V household battery and an ammeter in series and received a current measure of 10mA. This apparently wasn't strong enough to turn the fan. But then I connected my CPU fan to a 12V Universal Battery (model: UB1250ZH) and the ammeter, still in series with the circuit read 500mA, which started to spin the fan rapidly. Now I'm quite doubtful that a difference in 3V is enough to increase the current by that much so I'm pretty sure that the 12V battery has some internal resistors working but I have no idea how and why it works the way it does. Also, why do these batteries have ratings on them like "0.75A" Does that mean it's the maximum current the battery can preform under? Are there variable resistors involved? Thank you, any help will be very much appreciated. |
| Apr22-11, 05:19 PM | #2 |
Mentor
Welcome to PF.
Your devices will draw whatever amperage they want from the ac to dc adapter. 300mA is the amperage above which it is likely to overheat and burn-out. |
| Apr22-11, 05:38 PM | #3 |
Thanks! However, I'm still curious why the different batteries seem to be able to supply different currents.
| Apr22-11, 05:48 PM | #4 |
Power ratings on batteryBTW, there are such things as current sources. They are just much, much rarer than voltage sources because voltage sources are much easier to deal with. Finally, motors are very different from resistors. I don't quite know much more than that yet, though. |
| Apr22-11, 05:54 PM | #5 |
You also said that the fan draws more current than what the adapter is capable of supplying. However, I thought that the fan will draw a MAX of 0.57A...so can't it essentially draw anything under that depending on the voltage source? Please correct me if I'm totally incorrect to assume this. Thank you. |
| Apr22-11, 06:20 PM | #6 |
The current rating means that it can deliver up to 300mA without damaging the supply or current limiting circuitry kicking in. If you want to draw more current, you need a higher rated adapter. I'd go with 1A (1,000mA) rating for this use. The fan is rated for 12V, so the current will also be rated for that voltage. It will draw less current with a lower voltage, more current with a higher voltage, but it will draw 570mA at 12V. Bottom line, you need a 12V adapter rated for at least 1A. |
| Apr22-11, 07:03 PM | #7 |
Now I know you previously mentioned that motors are different from resistors but motors do still require current which consequently results in lowering the overall current in a series circuit. I conducted an experiment where I hooked up the fan and ammeter in series to a Transformer from part of my old toy train set which allowed me to turn a dial to adjust the voltage I wanted (up to 16V). I graphed the different currents that resulted from different voltages in an I-V graph (more or less linear) and took the inverse of the slope in hope to find the resistance of the fan. It came out as 25ohms. Can I be confident that this is in fact the true resistance of the fan and do I account the fan as a 25ohm resistor when I calculate total resistance and such when I start adding other components? Thank you so much for all you help! |
| Apr22-11, 07:26 PM | #8 |
Mentor
![]() The reason for an ac/dc adapter is the physical size of the components (and therefore cost) determines how much amperage they can handle. [edit: sorry, missed the big part....] |
| Apr22-11, 07:49 PM | #9 |
I do have a rating which says 5Ah but that wasn't what I was referring to earlier. There's a little chart on the battery that says... Standby Use: 13.6V-13.8V; 0.75A Cyclic Use: 14.5V-14.9V; 1.5A Not too sure what those terms mean though. And thank you for your help! |
| New Reply |
| Tags |
| battery, current, electricity, resistance, voltage |
| Thread Tools | |
Similar Threads for: Power ratings on battery
| Power from a battery PLEASE HELP! | Introductory Physics Homework | 2 | ||
| battery power | Electrical Engineering | 5 | ||
| Amperage ratings on DC power supplies | Electrical Engineering | 3 | ||
| Battery power | Classical Physics | 21 | ||
