Conservation of linear momentum understanding
The discussion revolves around the principle of conservation of linear momentum, particularly in relation to Newton's laws of motion. The original poster seeks clarification on the definition of the principle, the meaning of net external force, and how this principle connects with Newton's first, second, and third laws.
  • Participants explore the definition of net external force and its implications for a system of particles. There are attempts to relate the conservation of momentum to Newton's laws, with some questioning how momentum is conserved in collision scenarios.
Several participants have provided insights into the relationship between Newton's laws and conservation of momentum. There is an ongoing exploration of how to apply these concepts in practical examples, particularly in collision problems. While some clarifications have been offered, there is no explicit consensus on all points raised.
Participants are discussing the implications of impulsive forces in collisions and how they affect momentum conservation. The original poster has expressed a need for further understanding of Newton's second law, indicating a focus on foundational concepts.
faisal
I need help understanding the principle of conservation of linear momentum here's the definition.
priciple of conservation linear momentum is when there is no net external force (what does net external force mean?) acting on a system (what system?)of particles the total momentum of the system is conserved.
how does this law coincide with Newtons 1st 2nd and 3rd law?
p.s.
could u please help me understand Newtons 2nd law?
Salam alaikom bro. ;)
Newton's 2nd law is basically an object accelerates in the direction of the force applied to it..
Think about playing tennis with a friend, when you apply the force for the ball to go all the way to him with your racket, if he merely held his racket up and the ball hit it with this force, the ball would then accelerate in the direction of your force!
Momentum is... different I guess, basically, let's say two cars are moving at different speeds, for example one is moving at 40ms^-1 and another is at 20ms^-1, the first car has a mass of 1000kg and second car has a mass of 1200kg, if you summed the momentum of these up, basically times 40 by 10000 and 1200 by 20 and add them, you would have the total momentum of the system.
Usually you're given info about what happens AFTER the collision, after they hit, so if I say car A is now going at 20ms^-1, you can EASILY find out how fast the other one is going algebraically, so the formula would be:
40(1000) + 20(1200) = 20(1000) + v(1200)
And solve for v!
It's overly simplistic, hopefully what I said should make sense to you..
A net force or external force is any force applied which is outside nature, in other words any force by someone or something..
When it says system, it means the objects or bodies that are colliding, in this case the two cars...
Newton's first law says that an object will not change its state in motion unless a net force is applied, and this relates to the conservation of linear momentum in a way that these two laws both state that the values would be equal as long as no net force is applied.
Second law, too tired to think right now and give you a straight answer. :-\
Third law, same as the above..
Hoped some of this helped!
Ramadan kareem, bro.
The 2nd Law is related as
[tex]\sum_{i=1}^{n} \vec{F}_{i} = \frac{d \vec{P}}{dt}[/tex]
If [itex]\sum_{i=1}^{n} \vec{F}_{i} = 0[/itex] then linear momentum doesn't change, and thus it remains constant. That's why It's called the conservation of linear momentum.
Also, it's good to notice in collisions, momentum is not necessarily conserved, the problem is Impulsive Forces are so big compared to the other forces acting on the body, that you could discard them, and use conservation of linear momentum in collision problems.
Thanks for the informative replies (shukran Pseudo Statistic :smile: ), u cleared up a lot of problems for me.
P.s.
hope u'r have have a great Ramdan
  • · Replies 18 ·
  • · Replies 17 ·
18K
