Finding Moment of Inertia for a Uniform Thin Solid Door
The discussion revolves around finding the moment of inertia for a uniform thin solid door, with specific dimensions and mass provided. The subject area is primarily related to rotational dynamics and the application of moment of inertia concepts.
  • The original poster inquires about the necessity of calculus for solving the problem. Some participants suggest using integration to find the moment of inertia, while others mention a formula specific to rectangular plates.
Participants are exploring different methods to approach the problem, including integration and the use of a standard formula for rectangular plates. There is no explicit consensus, but various avenues for solving the problem are being discussed.
The original poster has provided specific dimensions and mass for the door, which may influence the choice of method for calculating the moment of inertia. There is also a suggestion of using calculus, indicating a potential complexity in the problem setup.
jmf322
Can someone point me in the right direction on how to find the moment of inertia of a uniform thin solid door, height 2.2 m, width .870 m and mass 23 kg. Do I need to use calculus to solve this type of problem? thanks!
moment of inertia = Integrate[r^2 dm] where dm is given by a density * an appropriate differential. r is perpendicular distance from the mass element to the axis of rotation. the bounds of the integral and the dm are given by the geometry of the problem.
Use the moment of inertia of an uniform rectangular plate
[tex]I_{cm} = \frac{1}{12}M(width^2 + height^2)[/tex]
sweet thanks guy, i got it! laters
  • · Replies 40 ·
15K
  • · Replies 21 ·
