New Reply
Why can maximum shear stress in a web be replaced by the average shear stress?
Share Thread Thread Tools
Apr23-11, 10:24 PM   #1
I've been reading my strength of materials text about design of steel beams. I understand everything up to the point where the text tells me to use the average web shear stress (V/dt) instead of max shear stress (VQ/It) to determine if a given beam is within the allowable shear stress. I calculated both to determine how close they are and found the average greater than the max! I've checked several times and don't see an error. What am I missing?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr23-11, 10:44 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by mtnmama View Post
Are you using a wide flange (I) beam? Max shear stress at the neutral axis (VQ/It) is approximately equal to the average shear stress when using the web area only (V/Aw).
Apr24-11, 12:30 PM   #3
Yes, it is a wide flange. When I calculate an average and a max stress on the flange of a 8 ft section of W18 x 50 with a uniform load of 1.85 klb/in I get an average of 16.22 klb/sq in. The max I get is 6.56 klb/sq in. Is that considered close, or have I made an error somewhere?
Apr24-11, 01:14 PM   #4
Please show your working.
Apr24-11, 02:07 PM   #5
I found some errors in Q. What I get now is:
V = wL/2 = [1.85 klb/in * 8 ft *12 in/ft]/2 = 88.80 kips
I = 400 in^4 (table)
Q = sum of first moments of upper half of beam, ie the flange and half the web
= Q of flange + Q of 1/2 web
= A of flange x y to centroid + A of 1/2 web x y to centroid
= (7.495 in * .57) * 8.71 + (8.425*.355*4.2125)
= 37.21 + 12.60
= 49.81 in^3
Max stress = VQ/(It) = 88.80 * 49.81 / (800 * .355) = 15.57 ksi
Avg stress = V/A of web = 88.89/(.355 * 15.42) = 16.22 ksi
These two values are close enough to verify that the max stress can be approximated by avg stress. If you don't see any errors in my equations, I will continue to use the approximation with confidence.
Thank you.
New Reply
Tags
beam design, shear stres
Thread Tools
Similar Threads for: Why can maximum shear stress in a web be replaced by the average shear stress?
Thread Forum Replies
Maximum Shear Stress Advanced Physics Homework 1
Shear stress in Energy-momentum Stress Tensor Special & General Relativity 16
Average Shear Stress on a Plate Engineering, Comp Sci, & Technology Homework 2
Maximum shear stress in square tubing Mechanical Engineering 1
average shear stress Engineering, Comp Sci, & Technology Homework 7
