| New Reply |
Question about oscillating currents. (the sign of the phase constant) |
Share Thread |
| Apr24-11, 05:24 PM | #1 |
This is more of a conceptual problem I'm having with in a problem. I'm trying to find the phase constant of the equation for a capacitor that is charging at time zero. I'm having trouble with figuring out what sign the phase constant should have. 2. Relevant equations q=Qcos([tex]\omega[/tex]t+ [tex]\vartheta[/tex]) dq/dt=-[tex]\omega[/tex]Q sin([tex]\vartheta[/tex]) 3. The attempt at a solution Ok, I know the max charge on the capacitor, and I know q at time zero, so I solved for the angle. I just don't know how to determine it's sign (the answer is positive). So here is one way of thinking about it: dq/dt should be positive because the capacitor is charging. Therefore -[tex]\omega[/tex]Q sin([tex]\vartheta[/tex]) must be positive which only happens when I choose the negative angle. Voila, the angle is negative if it is charging. BUT, I thought that if the capacitor was charging, the current should be decreasing? So how can dq/dt (which is the current) be positive if the capacitor is charging? Based on the two equations for energy U=q^2/2C and U=Li^2/2, if the charge increases the current must decrease to conserve energy. I seem to be contradicting myself. EDIT: Nevermind, I got it. The current is decreasing, but it is still positive for the capacitor to be charging. |
| New Reply |
Similar Threads for: Question about oscillating currents. (the sign of the phase constant)
| Foucault currents / Eddy Currents vs material selection | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Oscillating pendulum question | Introductory Physics Homework | 4 | ||
| currents in two same direction, they attract ?currents are going in opposite repel? | General Physics | 10 | ||
| Question: coupled oscillating circuits | Introductory Physics Homework | 11 | ||
| Question: A magnetic dipole m(t) is oscillating... | Advanced Physics Homework | 2 | ||
