Circular motion (conical pendulum)
The discussion revolves around a problem involving a conical pendulum, where a ball is attached to a string and moves in a circular motion while another ball hangs vertically. The original poster presents their attempts to analyze the forces acting on both balls and calculate the distance from the ring to the moving ball.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the horizontal and vertical force equations for both balls, with emphasis on the tension in the string and the gravitational forces acting on the hanging ball. There are attempts to derive relationships between the variables involved, such as speed, radius, and tension.
Some participants have provided guidance on the need for additional equations to fully describe the forces acting on both balls. There is acknowledgment of the original poster's efforts, and suggestions for clarifying the equations used, particularly regarding which mass corresponds to which force equation.
Participants note the importance of showing attempts to receive help and the constraints of the homework context, which may limit the type of assistance provided.
kingkong69
A ball, B, of mass 2kg is attached to one end of a light, inextensible string. The string passes through a smooth, fixed ring, O, and a second Ball, A, of mass 4 kg, is attached to the other end. B is made to move as a conical pendulum while A hangs vertically below the ring. If the speed of B is 7ms^(-1), how long is the section BO of the ring.
I drew a little pixie.
[PLAIN]http://img263.imageshack.us/img263/7783/54071583.png
F=mrW(angular velocity)^2, v=rWThe answer is 4/3 metres.
ATTEMPT:
my attempt:
solve horizontally, so mrW^2=(r/d)*T
r is radius on both sides, d is the distance BO, T is tension in the moving string
r/d is cosB
7=rW
W^2=49/r^2
so
98/r=(r/d)*T
Vertically
4*g=sinB*T
Im stuck here.
you must show your attempt in order to get help
my attempt:
r/d is cosB
7=rW
W^2=49/r^2
so
98/r=(r/d)*T
Vertically
4*g=sinB*T
and that's what i have so far
kingkong69 said:
Vertically
4*g=sinB*T
4*g is the weight of the hanging ball (A), not the moving ball (B).
You'll need vertical force equations for both balls.
please Doc Al be more specific
What forces act on each ball? Write force equations for horizontal and vertical components for each ball. (You've already done some of that.) You'll end up with three equations, which you'll solve together.
I understand I should solve it alone for my own benefit but I spent hours and I really stuck, sorry for being so reliant but will you help me out on this question?
welcome to pf!
hi kingkong69! welcome to pf! :smile:
(have an omega: ω and try using the X2 icon just above the Reply box :wink:)
kingkong69 said:
my attempt:
r/d is cosB
7=rW
W^2=49/r^2
so
98/r=(r/d)*T
Vertically
4*g=sinB*T
you need the vertical equation for B :wink:
As I mentioned in post #4, you need to correct this equation:
kingkong69 said:
Vertically
4*g=sinB*T
I think you meant that to be for the moving mass (B), but you used the wrong mass.
You also need an equation for the vertical forces on the hanging mass (A). (That one's easy.)
Got it! Thanks a ton!
