Jumping over objects while in motion
  • Context: Undergrad
  • Thread starter Thread starter kool_j
    Motion
The discussion focuses on implementing a jumping mechanic in a PC game where an object (objectA) must jump over a stationary object (objectB). The motion is modeled as a parabolic trajectory, with the x-component of velocity remaining constant while the y-component is influenced by initial velocity (y0) and gravitational acceleration (g). The formula used for the y-position over time is y(t) = y0t - (1/2)gt². Adjusting y0 and g allows for customization of jump height and gravity strength, essential for achieving realistic jumping dynamics in platformer games.
  • Understanding of rigid body physics in game development
  • Familiarity with parabolic motion equations
  • Basic knowledge of game physics engines
  • Experience with programming in a game development environment
  • Research "Unity Rigidbody physics" for implementing jumping mechanics
  • Learn about "Unreal Engine Blueprint for character movement" to enhance jump dynamics
  • Explore "Game physics simulation techniques" for realistic motion modeling
  • Investigate "2D platformer jump mechanics" for specific design patterns
Game developers, particularly those working on platformer mechanics, physics programmers, and anyone interested in enhancing character movement in video games.
kool_j
Hi,
I'm in the process of designing a PC game and I need to make objectA ,which is driving along to jump over object B which is stationary in its path. Can anyone tell if there is a formula to work out this type of motion.
Thanks :cry:
A simplistic way to do it would be to assume the jumper is like rigid body and follows a parabolic path while in the air. Let's call the direction in which the jumper is running the x-direction and up will be the y-direction.
Then when jumping, the x-component of the velocity will not change.
For the y-direction, you'll have to know how high he/she will jump, which is determined by it's initial velocity in the y-direction. Let's call it y0.
Then [itex]y(t)=y_0t-\frac{1}{2}gt^2[/itex].
For your game I think you'll have to tweak [itex]y_0[/itex] and g.
A higher y0 means a more powerful jump.
A higher g means a stronger gravitational field.
I assume youre looking at the object that's jumping from side on right?
(Like a Platformer) I also assume that you must be keeping its x, y
velocities independent from each other.
y
|________ x
If that's the case, keep your x-velocity constant as the jump is made.
To start with, set the y-vel to some positive value.
(yVel = startYVal)
(This will set how high you want to jump)
As time passes, change your y-velocity as follows:
yVel = oldYVel - g*t**2,
(where t is time and g is some constant that will set your gravity)
When yVel == - startYVal, then set yVal to 0 and end your loop.
(Otherwise your character will just fall straight through the platform)
This should give you a nice parabollic shape for your jump.
Sorry... I couldn't think of any simpler terms to explain this in.
Enjoy making the game! :biggrin:
  • · Replies 24 ·
  • · Replies 66 ·
  • · Replies 39 ·
