| New Reply |
Circuit completion : is it necessary? |
Share Thread |
| Apr28-11, 07:19 AM | #86 |
| Apr28-11, 07:24 AM | #87 |
The difference between this and the battery is that a battery is NOT a source of extra built up charges. Static electricity is however. An extreme example of this is Lightning. If lightning struck one terminal of your bulb you can bet your singed face that the bulb "lit up". (And more) |
| Apr28-11, 07:27 AM | #88 |
Anyway, the only way one would get shocked by touching only one of the terminals is if the current travelled through you and went through the ground to find it's way back to the source. To be clear... I know the ground wire has nothing to do with completing the circuit under normal conditions. It's there to complete the circuit only if something goes wrong. If that point didn't come through in my explanations, I apologize because it is an important one. |
| Apr28-11, 07:29 AM | #89 |
So the only problem is that a battery requires electrons to return back to the other terminal to show any significant movement of charges.
Any voltage source that does not show this property? |
| Apr28-11, 07:34 AM | #90 |
I believe (but I'm not certain) that this gets to the bottom of what the OP was asking... |
| Apr28-11, 07:41 AM | #91 |
| Apr28-11, 08:06 AM | #92 |
I think you mean a general device which supplies electrical energy. However the term voltage source has a much narrower and more precisely defined meaning in circuit theory. Incidentally much confusion arises when special definitions from circuit theory are introduced into a discussion about physics and vice versa. Circuit theory is much more specialised and limited than Physics and in particular makes certain assumptions for ease of analysis and calculation, that are not realisable in the real world . |
| Apr28-11, 09:42 AM | #93 |
Ahh, and to actually answer the question.
The OP is clearly trying to find a relation between his knowledge of 'static electricity' and 'battery electricity', into some sort of unified understanding. Assuming that parasitic capacitances are zero does not permit unified understanding. The situation is such that e.g. 2 A*h battery has a charge of 7 200 Coulomb stored chemically inside. The stray capacitance of, say, 1pF at potential difference of 12v stores 0.00 000 000 012 Coulombs. That is why it is very common to neglect stray capacitances when discussing batteries. edit: whoops mixed up mAh vs Ah |
| Apr28-11, 10:27 AM | #94 |
You keep talking about potential as if you can have it at one point. You can't. Potential at one point is with respect to another point... In this case we're talking about the potential between the rod and the negative pole. This potential is ZERO VOLTS in this case. No current flowed. No light bulb lit. You're trying to invent capacitance where it doesn't exist. The answer to the question in post #1 is the bulb absolutely will not light. No way it can. This stray capacitance that may or may not exist will in no way provide enough current for any glow to occur. |
| Apr28-11, 11:10 AM | #95 |
The electric potential at a point in an electric field is defined as the work done in moving a unit charge from infinity to that point. |
| Apr28-11, 11:36 AM | #96 |
This thread has bi-polar disorder, I think. On the one hand we have the transformer / live/ neutral discussion and, on the other hand, we have the connect a battery and what happens discussion. Whilst it's all 'Electricity', they two ideas are interfering with each other. It's OK for someone who knows about these things but, for someone fresh, it makes things much harder than necessary.
The power engineering discussion is made complicated by the fact that the neutral we all know and love in the UK is fairly different from the Neutral that goes into many US homes. Essentially, the Neutral which a three phase distribution system takes very little current, when the three phases are loaded equally. This keeps the Neutral volts pretty near Earth all the time. The Neutral that goes into the US home, as I understand, comes from a local transformer which is centre tapped to give both a 110V and 220V supply. It is, inherently, not balanced and, depending on the lopsidedness of a typical domestic load during the day, you could expect some much higher volts on a Neutral. You really don't want lots of earth currents sloshing around your domestic pipes and steel frames as it can cause embarrassing Hum, for a start. Current in the Neutral cable runs right next to the Live current and there is much less magnetic field generated. So - using the Neutral for return makes sense - else, why not have a single line supply to the home and rely on Earth as a return? Think of the copper you'd save! |
| Apr28-11, 12:00 PM | #97 |
http://en.wikipedia.org/wiki/Electric_potential 2: I was speaking of difference of potentials. Not a single result depended on the absolute potential (which i suppose is defined as energy of unit charge brought in from far outer space) I'd really love to know, because i am building some electronic circuit where I have to calculate capacitance of every piece of wire. |
| Apr28-11, 12:08 PM | #98 |
I find it bizarre that we are discussing picoCoulombs on the one hand and Mains supply currents on the other. |
| Apr28-11, 03:20 PM | #99 |
Also when you say you can't get shocked by touching just the hot wire, I'm doubtful about that too. I understand there is a lot of resistance between you and the ground, but I hear a lot of warnings about not sticking your finger in the socket. The current would have to travel through you, through the floor, and through metal piping which sounds like a lot of resistance, but it only takes a little current to kill you. |
| Apr28-11, 03:37 PM | #100 |
The fact there is 10 volts between the neutral and ground suggests that maybe you are right and neutral only connects to the center tap, where it has been reduced to 10V with respect to the ground by previous transformers. But according to hyperphysics, the neutral and ground wire are physically tied together at a location and driven into the ground before the center-tap location. I don't understand why a third prong is needed for ground. Can't you just plug the chassis of an appliance directly to neutral? Or is that what is done? Because I notice some appliances only have two prongs. Does this mean the chassis of the appliance shares the same connection to neutral as the appliance itself, i.e. two wires connect to the neutral prong? |
| Apr28-11, 04:53 PM | #101 |
Three phase generation is a great invention but it does generate a lot of conceptual problems. |
| Apr28-11, 05:04 PM | #102 |
You have a battery and a resistor. You connect one end of the resistor to one terminal of the battery. Does anything happen? No. No complete circuit. No current flow. Now replace the battery with an AC source. No grounds, no plumbing, nothing but an AC source with two terminals. Now.... connect one end of that same resistor to only one terminal of the AC source. Does anything happen? No. No complete circuit. No current flow. Now replace the resistor with yourself... see my point now? Introducing "ground" into the conversation complicates things and confuses people... They added a "ground wire" (third prong) that bonded all the metal things in your house together and tied it together with the neutral (at the service entrance) to create a parallel path back to the source. The reason they did this was in case of a fault, this current would travel back along the low resistance "ground wire" back to the source instead of through your body. If you simply tied everything to the neutral, then under "normal conditions" you would have current flowing through the neutral AND through all of the metal things in your house. This is not a desirable situation. |
| New Reply |
Similar discussions for: Circuit completion : is it necessary?
| Simple circuit completion counter | Electrical Engineering | 5 | ||
| Incomplete and completion | Differential Geometry | 2 | ||
| Completion of a metric space | Calculus | 7 | ||
| Completion | Calculus & Beyond Homework | 25 | ||
| Completion problem | Introductory Physics Homework | 7 | ||
