Temperature of minimum density
In summary, water does not have a minimum density temperature as it continuously decreases with an increase in temperature and eventually reaches a constant value. This is due to the fact that at high temperatures, water undergoes thermal decomposition, where it dissociates into hydrogen and oxygen gas. However, there is no specific temperature at which this occurs, as it is an equilibrium process and the percentage of water decomposed varies at different temperatures.
zorro
1,384
What is the temperature at which water possesses minimum density?
Chemistry news on Phys.org
This is tricky, for several reasons. But you are here long enough to know you should show your attempts first, and you know enough to see why it is tricky.
One reason I can think of is that usually the question is about 'maximum density', which is at 4 C.
haha what attempts should I make for a question like this? Random guesses 50C 60C 100C ? I think its better to keep quiet than to talk something silly.
Abdul Quadeer said:
Random guesses 50C 60C 100C?
These don't have to be random - just find a density vs temperature table.
However, what about 200 deg C?
Why would I post the question here if I had already found that table? :biggrin:
I searched on the internet but could not find it.
So 200 deg C is the answer?
I think you are lying, the way 3 years old kids do.
http://lmgtfy.com/?q=density+temperature+water+table
No. Instead of waiting for being spoon feed start to think.
Yeah anyone would say that after reading my post. Actually my mind was wandering somewhere else while writing that. I did find some graphs/tables but they were only for a short range of temperatures like 0-30 C, 0-80 C from which I could not deduce anything as the graph decreased continuously. In short I could not find a minima of the curve.
I think there is no such temperature...the density decreases continuously with increase in temperature and attains a constant value. So we cannot mention only one temperature for minimum density
Constant?
It cannot decrease infinitely and become negative so there should be a limiting or constant value.
Sigh.
You have a constant mass, when heating volume goes up. Density is a ratio of these values. Idea that it can get negative is out of this world.
What happens to water when heated?
Its starts evaporating at 100 oC and changes its phase above this temperature.
d ∝ 1/V, can we indefinitely increase the volume by heating?
Good question. In the realm of ideal gases - yes. But water is not ideal. What may happen at 200 deg C? 2000 deg C? 20000 deg C? What happens to all compounds at high temperatures?
The final phase of a compound is a gas which is attained above its boiling point/sublimation point. I don't know what happens to it if we keep on heating.
You probably know, you just don't realize it is universal. Have you heard about thermal decomposition?
Oh yes I know about it. But never heard it being used for water. So at some high temperature, water dissociates into hydrogen gas and oxygen gas. I think this temperature must be the temperature of minimum density because volume becomes maximum.
You are on the right track - wasn't that hard, eh?
Trick is, there is no simple single temperature at which you can say "water decomposes here". It is an equilibrium process, so all we can do is to calculate percentage of water that is decomposed at given temperature - no idea about exact numbers, according to wikipedia at 2200 °C about 3% of water decomposes, at 3000 °C above 50% and so on. So there is no simple answer to the question as asked.
Its very easy but I did not think about it that way :redface:.
Thank you Mr.Ph! I understood it now.
1. What is the temperature of minimum density?
The temperature of minimum density is the temperature at which a substance reaches its highest density. This is also known as the "maximum density temperature".
2. Why is the temperature of minimum density important?
The temperature of minimum density is important because it affects the physical properties of a substance. For example, in water, the temperature of minimum density is 4 degrees Celsius, which allows for aquatic life to survive in colder temperatures as the water at the bottom of a lake or ocean does not freeze.
3. How is the temperature of minimum density calculated?
The temperature of minimum density is calculated by measuring the density at different temperatures and plotting them on a graph. The point at which the density is highest is the temperature of minimum density.
4. Does every substance have a temperature of minimum density?
No, not all substances have a temperature of minimum density. For example, gases do not have a temperature of minimum density as their density decreases as temperature increases.
5. Can the temperature of minimum density change?
Yes, the temperature of minimum density can change depending on the pressure and composition of a substance. For example, in water, the temperature of minimum density can change if there are impurities or if the pressure is altered, such as in deep ocean water.
  • Chemistry
