Calculating Arc Length in Multivariate Calculus
The discussion focuses on calculating the arc length of the vector function r(t) = <3t, 4cos(t), 4sin(t)> from t=0 to t=1. Participants confirm that the derivative r'(t) equals 5, leading to an integral calculation that also results in 5 for the arc length. The geometric interpretation involves a right triangle with a base of 4 and a height of 3, suggesting a cylindrical wrapping around a radius of 4. The conclusion is that the calculated arc length of 5 is indeed correct.
  • Understanding of vector functions in multivariate calculus
  • Knowledge of derivatives and integration techniques
  • Familiarity with the arc length formula in calculus
  • Basic geometric concepts related to right triangles and cylinders
  • Study the arc length formula for parametric curves in multivariate calculus
  • Explore the geometric interpretation of vector functions
  • Learn about the applications of arc length in physics and engineering
  • Investigate the properties of cylindrical coordinates in calculus
Students and educators in multivariate calculus, mathematicians interested in vector functions, and anyone seeking to understand the geometric implications of arc length calculations.
crazynut52
here is the problem, and I can't seem to get very far,
compute the length of r(t) = <3t, 4cost, 4sint> from t=0 to t=1
i know the formula is integral from 0 to 1 of length of r'(t)
but I keep coming up with 5, and it doesn't seem right, can someone please confirm or deny this. Thanks
that seems to be what i get too. r'(t) = 5, so when you integrate this from 0 to 1 it gives you 5 again.
If you look at what you've plotted, i believe it is the hypotenuse of a right triangle with base 4 and height 3 wrapped around a cylinder [of radius 4].
