Periodic Surface Waves Produced by Non-Periodic Disturbances
The discussion focuses on the relationship between periodic surface waves and non-periodic disturbances in fluid dynamics, specifically in deep water. The angular frequency ω of a periodic surface wave is defined as ω = sqrt(gk), where g represents gravitational acceleration. The phase velocity V_{p} is derived as V_{p} = sqrt(gλ/2π), linking it to the wavelength λ. The phenomenon of dispersion explains how localized non-periodic disturbances can evolve into periodic waves as different wavelengths travel at varying speeds, ultimately grouping together at the shore.
  • Understanding of fluid dynamics principles
  • Familiarity with wave mechanics and equations
  • Knowledge of gravitational acceleration (g) and its role in wave motion
  • Concept of dispersion in wave theory
  • Study the derivation of wave equations in fluid dynamics
  • Research the concept of dispersion in wave mechanics
  • Explore the effects of localized disturbances on wave propagation
  • Learn about the application of phase velocity in different fluid scenarios
Students preparing for physics exams, particularly in fluid dynamics, and professionals studying wave behavior in various mediums.
Caveman11
This is part of a past paper I am trying to work through before a physics of fluids exam in a month.The angular frequency ω of a periodic surface wave with wavenumber k on
deep water is
ω = sqrt(gk)
where g is the gravitational acceleration.
Obtain an expression for the wave’s phase velocity in terms of its wavelength
and explain how a localized non-periodic disturbance far out at sea can lead
to approximately periodic surface waves at the shore.
Relevant equations:
[tex]V_{p}[/tex]=[tex]\frac{\omega}{k}[/tex] (Phase Velocity)
3. The Attempt at a Solution : I obtained a value for [tex]V_{p}[/tex] as:
[tex]V_{p}[/tex]=[tex]\sqrt{\frac{g\lambda}{2\pi}}[/tex]
Which I assume to be correct. However I can't explain the fact that you can get periodic waves from non-periodic motion. The only explanation I could think of was that the waves with the same wavelength travel together as they have the same phase velocity where as longer wavelength waves have a higher phase velocity and can overtake the slower ones. This would lead to after a while all the different periods being grouped together?Many Thanks
Yes. That's "dispersion" for ya!
I didn't expect it to be be that, Thanks
  • · Replies 0 ·
