Why Don't Electrons in Atoms Orbit Like Planets?
  • Context: Graduate
  • Thread starter Thread starter Cheman
    Atoms Electrons
The discussion revolves around the behavior of electrons in atoms compared to planets in orbit around the sun. Participants explore the implications of quantum mechanics, particularly the uncertainty principle, on electron motion and the validity of classical models like the Rutherford model.
  • Some participants assert that due to the uncertainty principle, electrons do not follow circular paths like planets, suggesting a more random motion influenced by various forces.
  • Others argue that the classical model of electrons in orbit is outdated, emphasizing that current models describe electrons as existing in defined states characterized by quantum numbers.
  • A participant questions why electrons do not take circular or elliptical orbits if they are influenced by a central force, proposing that the interaction with other forces may complicate their motion.
  • Another participant clarifies that the classical notion of well-defined initial velocities does not apply to electrons, highlighting the differences in behavior between atomic and macroscopic bodies.
  • Some contributions mention that at high principal quantum numbers, electron motion can resemble classical orbits, but this is contingent on specific conditions and does not imply classical behavior at lower energies.
  • Participants discuss the wave nature of electrons, noting that this characteristic becomes significant at atomic scales, contrasting with macroscopic objects.
  • There is a mention of Rydberg atoms, which can exhibit larger atomic sizes and periods of revolution that can be approximated using classical mechanics, although they still behave non-classically due to superposition of quantum states.
Participants do not reach a consensus; multiple competing views remain regarding the applicability of classical models to electron behavior and the implications of quantum mechanics on their motion.
Limitations include the dependence on definitions of classical versus quantum behavior, the unresolved nature of electron interactions in complex systems, and the varying interpretations of quantum states and their implications for electron motion.
Cheman
Right, as we know from the uncertainty principle we don't know exactly where an electron is, just where it most probably is. This implies that electrons don't follow circular paths like those of planets round the sun (as in the rutherford model) - they must take a more random path.
My question is if electrons are moving forward, like a planet, around the nucleus which is exerting a force on them, like the sun, why don't they take circular or eliptical orbits? Is it, quite simply, that electrons experience much more forces than the planets, interacting with forces from other electrons, atoms, etc?
Furthermore, does this suggest then that if there was no other matter in the universe (ie - no charges) a hydrogen atom would indeed look like one from the rutherford model - like a planet making a circular orbit of the sun?
Thanks in advance. :smile:
The model you are describing (electrons in orbit around nucleus) is an old model, which is considered quite out of date. Current models assign "states" to electrons, which are defined by quantum numbers and associated energies. If you want to picture it, think of a diffuse cloud (not too accurate a picture either) around the nucleus.
First of all, it is not nice to do multiple posting of the same question.
Secondly, I think you seem to not know the existence of the solution to the Schrödinger equation for the hydrogen atom. Please look it up and look at the orbital solutions. There is no need to "guess" or speculate what they look like anymore nowadays.
Zz.
Your question presupposes that the electron can have a well-defined initial velocity in the first place. Already, this thinking is doomed to be illusory, because we have no reason to think that this classical notion applies, and every reason to think that it does not.
No, it isn't. Even in the simple case of the 1-electron atom, the electron is (in the first approximation) subject to a central force, not unlike the central force that the Earth is subject to from the Sun (again, in the first approximation). The problem is not extra forces, the problem is that at the atomic level matter behaves very differently from macroscopic bodies. The wavelike characteristics of macroscopic objects is hidden by the fact that the wavelength associated with the wave is so small. At smaller scales, the wave nature of matter becomes more apparent.
It doesn't. Even if you take away the atom, and go to the simplest possible example of a beam of electrons passing through a single-slit diffraction apparatus, the wave nature of the beam would manifest itself in the form of a diffraction pattern, just like the one exhibited by light.
Electron motion can be described by circular or elliptical optics when the principle quantum number n is large. Then the correspondense principle applies: the electron's orbital period is the same as the radiation emitted in a quantum jump from n to n-1.
Nowadays laser experiments can be done on such Rydberg atoms. One can also do quantum mechanical calculations of the time evolution of small wave packets. Look at the animations of for example http://www.optics.rochester.edu:8080/users/stroud/ .
So let me get this straight, please correct me if I'm wrong - are you saying that an electron would do what I said bout ONLY IF it was like a planet round the sun. However, an electron is very different to this, and by its very nature is unlike things on a macromolecular level. Therefore, despite the fact that the electron is only experiencing one centrepetal force like a planets it behaves very differently to how a planet would.
Is that correct? :smile:
I don't want to give the wrong impression, so let me clarify. I'm not saying that there are 2 kinds of matter, one "microscopic" and one "macroscopic". I'm saying that quantum effects aren't apparent at the macroscopic level. I'll further state that if an electron had sufficiently high energy (say, as much energy as a planet in orbit), the expectation value of its position would approach the Newtonian result, as per the correspondence principle.
Not quite. Again, it has to do with the wave effects being unapparent at the planetary level. The deBroglie wavelength of a quantum particle is λ=h/p. For planets, p is much, much larger than it is for your typical atomic electron, so the wavelength is much, much shorter; many orders of magnitude shorter in fact.
You do not need to go that far. already when the principal quantum number n=100, you get an atom with diameter [tex]2 n^2 a_0 \approx 1\mu{\rm m}[/tex]. These Rydberg atoms are about the size of bacteria, and the periods of revolution are well calculated using Newtons laws and the Coulomb force.
(But of course these states are coherent superpositions of different quantum states, and behave non-classical because of that.)
Thank you. I didn't feel like doing any calculations, so I posted a "sufficient" condition, not a "necessary" one. :redface:
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 36 ·
10K
  • · Replies 22 ·
