Active Filter Derivation
by dillonmhudson
Tags: active, derivation, filter
dillonmhudson
dillonmhudson is offline
#1
Apr29-11, 04:29 PM
P: 50
Can I get some help with this? I don't even know where to begin.
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
jegues
jegues is offline
#2
Apr29-11, 05:07 PM
jegues's Avatar
P: 1,079
Quote Quote by dillonmhudson View Post
Bandpass filters usually employ both inductors and capictors.
The inductor cuts off the high frequencies, while the capacitor cuts off the low frequencies, ideal for a bandpass filter.
jegues
jegues is offline
#3
Apr29-11, 05:15 PM
jegues's Avatar
P: 1,079
Quote Quote by jegues View Post
Whoops, I just noticed that the the answer is given in the figure. I can see they did not use a capacitor!
I managed to derive the transfer function for this circuit and found the following,
[tex]T(jw) = \frac{-z}{(jwL + z)(jwL + R)}[/tex]
Now we simply need to select our Z such that the requirement for resonant frequency is obatined.
If we select,
[tex]z = R_{z}[/tex]
We rearrange the transfer function,
[tex]\frac{-\frac{1}{R}}{(1 + \frac{jwL}{R_{z}})(1 + \frac{jwL}{R})}[/tex]
This becomes,
[tex]\frac{-\frac{1}{R}}{(1 + \frac{jw}{w_{L}})(1 + \frac{jw}{w_{H}})}[/tex]
Now we know what wL and wH are we can solve for fL and fH since,
[tex]f = 2\pi w[/tex]
Then our desired resonant frequency,
[tex]f_{r} = \sqrt{f_{L} \cdot f_{H}}[/tex]
Simply solve for, [tex]R_{z}[/tex].
You should find that, [tex]R_{z} = \frac{100\pi^{2}L^{2}}{R}[/tex]
Register to reply
Related Discussions
First Order Active Low Pass Filter Engineering, Comp Sci, & Technology Homework 11
design an active filter 2nd order Engineering, Comp Sci, & Technology Homework 3
Active Second-order low-pass Butterworth filter Electrical Engineering 1
3rd order low pass Butterworth active filter Electrical Engineering 3
Active band pass RC filter Introductory Physics Homework 0
