Angular acceleration/tangential velocity
  • Thread starter Thread starter buffgilville
    Angular Velocity
This discussion focuses on calculating the ratio of tangential velocities and kinetic energies of two disks, A and B, rotating together with angular velocity ω. The radius of disk B is 2/3 that of disk A, leading to a tangential velocity ratio of 2/3. The kinetic energy ratio, derived from the moment of inertia formula I = 1/2*MR², shows that the kinetic energy of disk A is 9/4 times that of disk B, assuming equal mass distribution and density for both disks.
  • Understanding of angular velocity (ω) and its relationship to tangential velocity (v = rω)
  • Knowledge of moment of inertia (I = 1/2*MR²) for disks
  • Familiarity with kinetic energy calculations in rotational dynamics
  • Basic principles of mass distribution and density in physical objects
  • Study the relationship between angular velocity and tangential velocity in rotating systems
  • Explore the concept of moment of inertia for various shapes beyond disks
  • Investigate the effects of mass distribution on kinetic energy in rotational motion
  • Learn about energy conservation in rotating systems and its applications
Physics students, mechanical engineers, and anyone interested in understanding rotational dynamics and energy calculations in rotating systems.
buffgilville
Can someone please help me on how to solve this problem?
Two disks, A and B, are cemented together rotating with angular velocity a . The radius of the small disk B is 2/3 the radius of the larger disk A.
a) Calculate the ratio of the tangential velocity of a point on the rim of disk A to the tangential velocity of a point on the rim of disk B?
b) If the two disks in problem a have an angular velocity of w, calculate the ratio of the kinetic energy of disk A to the kinetic energy of disk B. Assume that each disk has a mass M.
a) How is, in general, tangential velocity at a radius "R" from the rotation axis coupled with angular velocity?
b) How is the kinetic energy of a rotating object related to the moment of inerta of the object with respect to the rotation axis and the angular velocity?
Assume that the mass distribution is equal for both disks.
(Use, for example, that each disk has a constant density in your calculations.)
a) To solve this problem, we can use the formula for tangential velocity, which is v = rw, where r is the radius of the disk and w is the angular velocity. Since the radius of disk B is 2/3 of the radius of disk A, we can calculate the ratio of the tangential velocities as follows:
vA/vB = (rA*w)/(rB*w) = (rA/rB) = (2/3)
Therefore, the tangential velocity of a point on the rim of disk A is 2/3 times the tangential velocity of a point on the rim of disk B.
b) To calculate the kinetic energy of each disk, we can use the formula KE = 1/2*I*w^2, where I is the moment of inertia and w is the angular velocity. Since both disks have the same angular velocity, we can ignore it in the ratio calculation.
KEA/KEB = (1/2*IA)/(1/2*IB) = IA/IB
The moment of inertia for a disk is given by I = 1/2*MR^2, where M is the mass of the disk and R is the radius. Substituting in the values for disk A and B, we get:
KEA/KEB = (1/2*M*A*R^2)/(1/2*M*B*(2/3*R)^2) = (1/2*M*A*R^2)/(1/2*M*B*4/9*R^2) = (9/4)*(A/B)
Therefore, the kinetic energy of disk A is 9/4 times the kinetic energy of disk B.
  • · Replies 24 ·
