Why do comets tails come out of the front and curve around to the back?
  • Context: High School
  • Thread starter Thread starter Cbray
    Comet Comets Curve
Comet tails originate from the coma, which forms as the comet approaches the sun, primarily due to heating and radiation pressure. The tails consist of two components: one made of gas and ions, and another composed of dust, which follow different trajectories. The gas and ions are pushed away from the sun, while the dust remains in the comet's orbital path. The curvature of the tails is influenced by the bow shock created by the solar wind and the anisotropic distribution of ices on the comet's surface.
  • Understanding of cometary structures, specifically the coma and tails.
  • Knowledge of solar radiation pressure and its effects on celestial bodies.
  • Familiarity with the concept of bow shock in astrophysics.
  • Basic principles of gas dynamics and particle behavior in space environments.
  • Research the formation and characteristics of comet comas.
  • Study the effects of solar radiation pressure on cometary materials.
  • Explore the dynamics of bow shock and its impact on comet tails.
  • Investigate the role of volatile compositions in comet tail formation.
Astronomy enthusiasts, astrophysicists, and students studying celestial mechanics and cometary science will benefit from this discussion.
Cbray
I've been researching this for a while now, and none of the theory's can predict it.
I've studied comets for a while now, and the tails come out of the front and then has a weird curve which goes to the back.
If you guys have any random ideas or thoughts of why this is happening, that would be awesome.
It's been stuck in my head for a while now,
thanks,
Charles.
Astronomy news on Phys.org
Baloney. Sorry, but that's the only sensible word for claiming that just because you don't understand something that therefore nobody understands it.
Comet tails do not come "out the front". A comet has a coma, which would be spherical, caused by the heating of the comet as its orbit nears the sun. This coma is distorted by the bow shock as the comet passes through the solar wind. On the trailing edge, a comet has two tails: one made of gas and ions and the other of dust. These point in different directions - the dust remains in the orbit ellipse and the gas and ions are pushed away from the sun.
What you're describing isn't the paradigmatic 'comet' that most people imagine... do you have a particular image you're thinking about?
Comet tails are caused by a few effects, the dominant one is simply heating and radiation pressure from the sun. The heat from sunlight evaporates (and ionizes) volatiles on the surface of the comet facing predominantly toward the sun, and then radiation pressure pushes the material away from the sun (regardless of the comet's trajectory---for the most part).
Generally this looks like a thin pseudo-atmosphere, roughly spherical around the comet, followed by a tail pointing away from the sun. I suppose (conjecturally), that particular comet structures (e.g. anisotropic distribution of ices on the surface, and particular volatile compositions) could lead to a more collimated outflow in a particular direction which takes some time for radiation pressure to redirect. This might be more likely if a large amount of the ejected material is heavier dusts (instead of just gas).
  • · Replies 27 ·
  • · Replies 28 ·
10K
  • · Replies 49 ·
  • · Replies 17 ·
  • · Replies 66 ·
