Spherical shell of charge / electron
The discussion centers on the calculation of potential energy for a spherical shell of charge and its implications for understanding the mass of an electron. The user employs the potential energy equation, integrating the electric field over a distance, and arrives at a result that suggests the electron's charge is effectively doubled in the calculations. This leads to confusion regarding the physical interpretation of the electron's charge distribution, particularly when considering the forces acting on it. The user seeks clarification on why the potential energy formulation appears to account for the electron's charge twice, despite only one charge being present.
  • Understanding of electrostatics, specifically Coulomb's law
  • Familiarity with potential energy concepts in physics
  • Knowledge of integration techniques in calculus
  • Basic principles of charge distribution in spherical geometries
  • Study the derivation of electric potential energy for spherical charge distributions
  • Explore the implications of charge distribution on mass calculations in particle physics
  • Investigate the relationship between electric fields and potential energy in electrostatics
  • Learn about the concept of effective charge and its role in particle interactions
Physics students, researchers in electromagnetism, and anyone interested in the foundational concepts of charge interactions and potential energy in particle physics.
Zaphodx57x
I am having a problem understanding this problem which references this exercise .
I tried it a couple different ways. I used
[tex]\begin{multline*}<br /> \Delta U(Potential Energy) = Uf - Ui = Uf - U(r = infinity) = Uf - 0 \\<br /> dU = Uf = -W = \int F * ds = \int E * Q * ds \\<br /> Uf = -\int E * Q * dr = -\int \frac{kqQ}{r^2} = \frac{kqQ}{r}<br /> \end{multline*}[/tex]
I also tried using the bare potential energy equation and using two arbitrary surface areas (dA) on opposite sides of the sphere with a distance between charges of 2r , then integrating each over just half of the sphere, which provided the same result.
The problem I have is that this result gives me a pretty decent result for the mass of an electron if I assume that q = Q = charge of an electron. But this assumption seems to say that the electron is pushing against itself by its full charge.
That is a force [itex]\frac{QQ}{r^2}[/itex] is present instead of a [itex]\frac {(Q)(q}{r^2}[/itex] where [itex]q = \frac {Q}{n}[/itex] or some other fractional or modified charge.
This almost makes sense to me in that if a sphere were to have a charge spread evenly over its surface and its radius is infinity, it still acts as if it has all its charge at its center and therefore would resist a decreasing radius of like charge.
If anyone can find a way to explain why this problem makes sense I would really appreciate it. I just don't understand how the Potential energy can contain the electron's charge twice, when there is only one charge to begin with.
there is a potential from one electron to BOTH other electrons
If you keep increasing the amount of particles that the electron is composed of, the approximation for mass gets worse. Going to two particles and then eventually one gives you a better approximation, but the concept behind how it works physically eludes me. Its as if the electron focuses all its charge at its center and simultaneously has the same charge spread out over the shell of charge.
Perhaps the cute mathematical answer is just an ends to a means, and the accumulation of potential energy from the radius decreasing from infinity to r just happens to simplify to a very concise answer. Anybody have any ideas?
  • · Replies 23 ·
