| New Reply |
Physics of Rocketry: Distance Traveled |
Share Thread | Thread Tools |
| May1-11, 11:51 PM | #1 |
Calculate the firing times for the acceleration and deceleration leg of the mission described below and also the distance traveled for each leg. I also need to calculate the initial mass of the vehicle.
1) acceleration leg from zero velocity to a final velocity of 25,000 m/s. 2) 360 'cruise' non-acceleration leg (constant velocity) at 25,000 m/s; systems shut down. 3) deceleration leg (delta V=25,000 m/s) This question is part of a bigger question of which I had to solve a couple things for. What's given: ISP=4000 seconds g=9.81 m/s^2 [tex]m_L[/tex]=7000 kg I have calculated the mass flow rate of the propellant to be .006371 kg/s and the mass of the engine to be 3.42485 kg. Here is my work thus far. initial mass=mass of engine + mass of payload + mass of propellant [tex]m_0=m_e+m_L+m_p[/tex] [tex]\frac{m_0-m_p}{m_0}=e^{\frac{-\Delta V}{ISPg_0}}}[/tex] So I solve the above equation for [tex]m_p[/tex] and put into the first equation to obtain the equation below solved for [tex]m_0[/tex]. [tex]m_0=\frac{m_e+m_L}{e^{\frac{-\Delta}{ISPg_0}}}[/tex] So plugging in the numbers where [tex]\Delta V[/tex]=25000, I get the initial mass of the vehicle to be 13243.5 kg. This seems reasonable. Now this is where I get confused, how do I go about solving for the propellant mass in each leg and the distance traveled. I believe that I have to do some sort of integration for the distance traveled due to the mass constantly decreasing. Is there an equation or integration set up for this already? |
| New Reply |
| Thread Tools | |
Similar Threads for: Physics of Rocketry: Distance Traveled
| Physics problem involving a gravitational change based on distance traveled. | Introductory Physics Homework | 25 | ||
| Distance traveled! | Introductory Physics Homework | 11 | ||
| Distance Traveled | Introductory Physics Homework | 5 | ||
| Distance traveled, v->c | Advanced Physics Homework | 13 | ||
| distance traveled | Introductory Physics Homework | 1 | ||
