Quick question to clear up some confusion on Riemann tensor and contraction
The discussion centers around the calculation of the Ricci tensor from the Riemann tensor, specifically addressing the process of lowering indices and the implications of different definitions of the Riemann tensor. It involves theoretical aspects of differential geometry and tensor calculus.
  • One participant seeks clarification on the process of lowering indices in the context of the Riemann tensor and its relation to the Ricci tensor.
  • Another participant corrects the notation used in the first post, indicating that the same index cannot appear multiple times in an expression.
  • A third participant explains the relationship between the Riemann tensor and the metric tensor, emphasizing that raising and lowering indices is performed using the metric and its inverse.
  • A later reply argues that the expression for the Riemann tensor with upper indices is more fundamental, as it is defined from the derivative operator without reference to a metric, while noting that obtaining the Ricci tensor from the Riemann tensor requires a metric.
Participants express differing views on the fundamental nature of the Riemann tensor and the necessity of the metric for certain calculations. There is no consensus on the interpretation of the symmetry properties of the Riemann tensor.
There are unresolved issues regarding the notation and the implications of lowering indices, as well as the assumptions underlying the definitions of the Riemann tensor and Ricci tensor.
Deadstar
Let's say I want to calculate the Ricci tensor, [tex]R_{bd}[/tex], in terms of the contractions of the Riemann tensor, [tex]{R^a}_{bcd}[/tex]. There are two definitions of the Riemann tensor I have, one where the [tex]a[/tex] is lowered and one where it is not, as above.
To change between the two all that I have ever seen written is 'we lower the indices' but I don't think I fully understand this. Does this mean...
[tex]R_{abcd} = g_{aa} {R^a}_{bcd}[/tex]
So the answer to my original question of finding the Ricci tensor is...
[tex]R_{bd} = g^{ac} g_{aa} {R^a}_{bcd}[/tex]
Following this, I also have written before me that...
[tex]{R^b}_{bcd} = 0[/tex] since [tex]R_{abcd}[/tex] is symmetric on a and b. Shouldn't this be antisymmetric on a and b?
Sorry if these are basic questions but I'm finding the vagueness of 'lowering the indices' a bit confusing...
Cheers.
You can't have the same index appearing 3 times in an expression, what you mean is
[tex]R_{abcd} = g_{ae} {R^e}_{bcd}[/tex]​
The Riemann tensor
[tex]R^{\alpha}_{\;\beta\gamma\delta}=g^{\alpha\lambda}R_{\lambda\beta\gamma\delta}[/tex].
The raising and lowing of indices is done using the fundamental metric tensor [itex]g_{\alpha\beta}[/itex] and the inverse metric [itex]g^{\alpha\beta}[/itex].
The Ricci tensor
[tex]R^{\alpha}_{\;\beta\gamma\delta}\rightarrow R^{\alpha}_{\;\beta\alpha\delta}=R_{\beta\delta}[/tex]
is a contraction of the first and third indices.
I would argue that [tex] R^{\alpha}_{\;\beta\gamma\delta}[/tex]
is the more fundamental expression for the Riemann tensor
since this is defined from the derivative operator [without reference to a metric].
Its trace yields the Ricci tensor [as jfy4 wrote]... and this too doesn't make use of a metric.
To lower the upper index of Riemann or to get the scalar-curvature from Ricci now requires a metric.
  • · Replies 28 ·
