Designing a Couette Cell - Get the Right Shear Gradient
  • Context: Graduate
  • Thread starter Thread starter J4MacDonald
    Cell Design
The discussion focuses on the design of a Couette cell, specifically the relationship between the diameters of concentric cylinders and the resulting shear gradient. A rotating cylinder with a diameter of 28.64789 mm and a static cylinder with a diameter of 29.64789 mm achieves a shear gradient of 3000/sec at 1000 RPM. Alternatively, a rotating cylinder with a diameter of 10.0 mm and a static cylinder with a diameter of 11.0 mm reaches the same shear gradient at 2864.789 RPM. The accuracy of these calculations is confirmed, particularly for the second scenario.
  • Understanding of Couette flow dynamics
  • Familiarity with rotational mechanics
  • Knowledge of shear gradient calculations
  • Basic principles of fluid mechanics
  • Research the mathematical derivation of shear gradients in Couette flow
  • Explore the effects of varying cylinder diameters on shear rates
  • Learn about the applications of Couette cells in rheology
  • Investigate the impact of RPM variations on shear gradient outcomes
Researchers in fluid dynamics, engineers designing rheological testing equipment, and students studying fluid mechanics will benefit from this discussion.
J4MacDonald
I believe I have an understanding of the proper design for a Couette cell. If I am incorrect, please let me know.
Two concentric cylinders, the internal one rotating, the external one static.
1.) If I have a rotating cylinder with a diameter of 28.64789 mm and a static one with a diameter of 29.64789 mm, then 1000 RPM will produce a shear gradient = 3000/sec
2.) If I have a rotating cylinder with a diameter of 10.0 mm and a static one with a diameter of 11.0 mm, then 2864.789 RPM will produce a shear gradient = 3000/sec
Thank you in advance.
The first answer should be about 1000/sec. The 2nd answer is correct.
  • · Replies 52 ·
9K
