How Do I Solve These Gauss' Law Problems for a Cylindrical Shell?
The discussion revolves around Gauss' Law applied to problems involving cylindrical shells and charge distributions. The original poster presents two problems: one involving a non-uniform charge density within a cylindrical shell and another concerning a hollow metallic cylinder coaxial with a charged wire.
  • Mixed
  • Participants explore different methods for calculating total charge and electric fields, questioning the validity of their approaches and the assumptions made regarding charge distributions.
Several participants have provided alternative expressions for the total charge in the first problem, with some expressing uncertainty about the correctness of their calculations. There is an ongoing exploration of the second problem, with hints and suggestions for simplifying the approach being offered.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a noted confusion regarding the interpretation of charge densities and their implications for the electric field calculations.
acgold
I'm stuck on two problems. I hope someone can help me. Here they are...
1) A positive charge distribution exists within a volume of an infinitely long cylindrical shell of inside radius [tex]a[/tex] and outside radius [tex]b[/tex]. The charge density [tex]\rho[/tex], is not uniform but varies inversely as the radius [tex]r[/tex] from the axis. That is, [tex]\rho=\frac{k}{r}[/tex] for [tex]a<r<b[/tex] where [tex]k[/tex] is a constant. (a) Find the total charge Q in a length L of the cylindrical shell and (b) starting with Gauss' Law, find the electric field at a point [tex]r[/tex] within the cylinder, [tex]a<r<b[/tex]. Answer a) [tex]Q=k 2 \pi L(b-a)[/tex] b) [tex]E=\frac{k (r-a)}{ \varepsilon_0 r}[/tex]
2) The axis of a long hollow metallic cylinder (inner radius 1 cm and outer radius 2 cm) is coaxial with a long wire. The wire has a linear charge density of -8 pC/m and the cylinder has a net charge per unit length of -4 pC/m. Derive an expression for the electric field outside the cylinder and determine the magnitude of the electric field at a point 3 cm from the axis. Answer 7.2 N/C
1) For 1a I thought Q would be [tex]Q=\rho \pi L (b^2-a^2)[/tex] but since [tex]\rho=\frac{k}{r}[/tex] so [tex]Q=\frac {k \pi L (b^2-a^2)}{r}[/tex]. After being stumped on 1a I'm not sure how to go about 1b.
2) I've derived about 4 equations for this problem (all wrong of course) and I get numbers like 4.7 N/C or so but never 7.2 N/C. I think the wire inside the cylinder is really screwing me up.
I'd really appreciate some help. Even a little nudge in the right direction would be great. Thank you thank you thank you
I get
[tex]Q = 2 \pi L k \ln{(b-a)}[/tex]
for question 1 a), which disagrees with the answer you quoted. Perhaps somebody could verify this.
Claude.
Hey thanks for the reply; could you give me a quick explanation on how you got that answer? Just understanding the process you went through would really help me a lot. Thanks.
Claude Bile said:
I get
Claude.
I find that the quoted answer is correct.
[tex]Q=\int\rho dV=L\int\rho dA=L\int\rho (2\pi r)dr=2\pi Lk\Delta r[/tex]
Yes, I see my error now. Thanks krab.
You need to start with definitions, in a question such as this one;
[tex]Q = \int_{V} \rho d\tau[/tex]
is a good place to start. Instead of performing a triple integral, utilize the symmetry of the cylinder to express dV in terms of dr, thus reducing it to a single integral.
Claude.
Ok I'm pretty sure I understand the first problem now.
Like Krab said for 1a) [tex]Q=\int^b_a \frac{k}{r} 2 \pi r L dr = k 2 \pi L \int^b_a dr = k2\pi L (b-a)[/tex]
Since the total charge is asked for you must integrate from a to b.
To find the charge for 1b) you have to integrate from a to r so [tex]q=k2 \pi L(r-a)[/tex] and [tex]E=\frac{k2 \pi L(r-a)}{\varepsilon_0 2 \pi L r}[/tex] which is simply [tex]E=\frac{k(r-a)}{\varepsilon_0 r}[/tex]
Thanks for the help. :biggrin: I'm still stuck on deriving an expression for #2 though. I'd really appreciate even just a hint to get me started. Thanks again!
Ok, I've been working on this problem for an insane amount of time but I never get 7.2 N/C. Can someone check the expression I came up with and tell me if it's right? This is for the second question...
[tex]\lambda L + \rho \pi L(b^2-a^2) = \varepsilon_0 E 2 \pi r L[/tex]
so
[tex]E= \frac{\lambda + \rho \pi (b^2-a^2)}{\varepsilon_0 2 \pi r}[/tex]
where lambda is the charge density of the wire, rho is the charge density of the cylinder, b is the outside radius, a is the inside radius, and r is the distance from the axis (r is greater than b).
If I plug in the numbers from the problem I do not get the answer quoted. What am I doing wrong here?
Your expression is no good. It also looks much more complicated than it needs to be. Hint: Since you only care about the field outside the cylinder, the net linear charge density is just the sum of that for the wire and the cylinder.
Is this correct?
[tex]\lambda L + \rho L = \varepsilon_0 E 2 \pi r L[/tex]
so
[tex]E= \frac{\lambda + \rho }{\varepsilon_0 2 \pi r}[/tex]
I just noticed that the problem gives the charge per unit LENGTH. Oops. Thanks for the help.
Looks good to me. (Assuming that [itex]\lambda + \rho[/itex] represents the two linear charge densities.)
