Projectile Motion (Initial Velocity)
by Milkster18
Tags: initial, physics, projectile, velocity
Milkster18
Milkster18 is offline
#1
May4-11, 11:52 AM
P: 22
Hi, im trying to find the initial velocity of this question:
Using a video camera, it is observed that when a ball is kicked from A, it just clears the top of a wall at B as it reaches its maximum height. Knowing the distance from A to the wall is 20m and the wall is 4m high, determine the initial velocity at which the ball was kicked. Neglect size of the ball ( Ans Ua = 23.9m/s).
So im thinking to find the angle you have to use trig :
so 20^2 + 4^2 = square root of 416 = 20.4m (hypotenuse)
using Sin, 4/ 20.4 = Invert Sin 0.196 = 11.3 degrees angle the ball is projected.
Now i have then angle what else do i need to find in order to find the initial velocity at which the ball was kicked?
Thanks for any help
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
Doc Al
Doc Al is online now
#2
May4-11, 05:29 PM
Mentor
Doc Al's Avatar
P: 40,874
Quote Quote by Milkster18 View Post
That angle is not the angle of the ball's initial velocity. The ball travels a parabolic trajectory, not a straight line.
Analyze the vertical motion first. Figure out the vertical component of the initial velocity.
Milkster18
#3
May4-11, 06:30 PM
P: 22
Ah ok, i thought about the ball not traveling in a straight line assuming the angle was wrong at some point.
Ok so if 'm trying to analyze the vertical component of the initial velocity im going to use equation:
Sy = Uyt + 0.5(ay)t^2 Or
Vy^2 = Uy^2 - 2g(Sy)
The 2nd equation i'm thinking i should use since it has just one unknown (Uy).
Vy = 0, Sy = 4m
0 = Uy^2 - 2(-9.81)(4)
I dont want to go further until i know what i'm doing so far is correct..
Doc Al
#4
May4-11, 06:46 PM
Mentor
Doc Al's Avatar
P: 40,874
Vy = 0, Sy = 4m
Almost perfect. You have an extra minus sign in your last equation. g is just the magnitude of acceleration, so g = 9.81, not -9.81. (The acceleration is -g = -(9.81) = -9.81 m/s^2.)
Milkster18
#5
May4-11, 07:21 PM
P: 22
Ok so
Uy^2 = 2(9.81)(4) + 0
Uy^2 = square root 78.48
Uy =8.86 m/s Correct?
What shall i do now?
Do i find the time?
Sy = Uyt + 0.5(9.81)t^
Sy = 4 + (8.86)t - 4.905t^2
Sy = 12.86t / 4.905^2
4 = 12.86 - 4.905
4 = 7.955
t = square root 0.5 = 0.7s
t = 0.7 s .. is this correct so far?
Doc Al
#6
May4-11, 07:37 PM
Mentor
Doc Al's Avatar
P: 40,874
Ok so
Yes. Good.
Do i find the time?
Right approach, but you messed up the equation:
(1) 4 is the final position, not the initial.
(2) a + bt ≠ (a + b)t
Even easier: What's the average vertical speed? Use that to find the time.
Milkster18
#7
May4-11, 07:53 PM
P: 22
Average vertical speed..
Uy / g
8.86 / 9.81 = 0.9 s?
(Sorry im getting tired as its nearly 2am)
Milkster18
#8
May4-11, 07:55 PM
P: 22
speed is calculating in m/s.. sorry im confused
Doc Al
#9
May5-11, 01:36 PM
Mentor
Doc Al's Avatar
P: 40,874
Uy / g
No. The vertical speed varies uniformly from its initial value of 8.86 m/s to 0 at the highest point. What do you think the average vertical speed would be?
Milkster18
#10
May5-11, 02:01 PM
P: 22
sice it highest point is Sy = 4m
is it 8.86 / 4 = 2.215 m/s average vertical speed?
if its not can you provide further help? thanks
Doc Al
#11
May5-11, 02:18 PM
Mentor
Doc Al's Avatar
P: 40,874
No. You cannot divide a speed by a distance and expect to end up with a speed.
Try this analogy: You start out making zero money and, uniformly, little by little, end up making $100/day. Over that time period, what was your average salary per day?
You may want to review some of the basic formulas of kinematics:
Basic Equations of 1-D Kinematics
Kinematic Equations and Problem-Solving
And here's some good stuff about projectile motion:
Projectile Motion
Milkster18
#12
May5-11, 02:36 PM
P: 22
u+v / 2 = the average?
So v = 0
8.86 / 2 = 4.43 m/s
Doc Al
#13
May5-11, 02:37 PM
Mentor
Doc Al's Avatar
P: 40,874
So v = 0
8.86 / 2 = 4.43 m/s
Good! So now that you have the average vertical speed and the vertical distance, figure out the time.
Milkster18
#14
May5-11, 02:43 PM
P: 22
with the analogy:
Say you made 0$ to 100$ over 7 days .. average income per day is 100 / 7 = 14.3$ per day
Milkster18
#15
May5-11, 02:57 PM
P: 22
Sy = (4.43)t - (4.91)t^2
4 = (4.43)t - (4.91)
4 = -0.48?
4 / 0.48 = square root 8.33
t = 2.887 s ?
Milkster18
#16
May5-11, 02:58 PM
P: 22
Question: Why does the AVERAGE Initial vertical velocity have to be used instead of just the initial vertical velocity so i can understand why?
Doc Al
#17
May5-11, 03:21 PM
Mentor
Doc Al's Avatar
P: 40,874
with the analogy:
No. Your income increases from 0/day to 100/day. Like this:
0/day; 1/day, 2/day, 3/day...... 100/day. Average (assuming uniform increase--just like uniform acceleration) is (0 + 100)/2 = 50/day. Half the time you made less, half the time you made more.
(But don't worry about that analogy if it doesn't help.)
Doc Al
#18
May5-11, 03:26 PM
Mentor
Doc Al's Avatar
P: 40,874
4 = -0.48?
t = 2.887 s ?
No, using that method you would use the initial velocity, not the average velocity. You'll end up with a quadratic to solve.
Again, using that method you would use the initial velocity.
I wanted to show you an easier way to get the time, using Distance = ave speed X time. No quadratics to solve. (Do it both ways and compare the answers.)
Register to reply
Related Discussions
For projectile motion, can the y-final velocity be less than the y-initial velocity? Introductory Physics Homework 1
Projectile motion, with no Initial Velocity Introductory Physics Homework 5
Projectile Motion - Initial velocity Introductory Physics Homework 1
Projectile Motion (No initial velocity) Introductory Physics Homework 1
Initial velocity in projectile motion Introductory Physics Homework 22
