New Reply
Jordan Normal Form / Jordan basis
Share Thread Thread Tools
May4-11, 02:52 PM   #1
Determine the Jordan Normal form and find some Jordan basis of the matrix
3 -3 1
A = 2 -2 1
2 -3 2
2. Relevant equations
dim(A) = rk(A) + dimKer(A
3. The attempt at a solution
My problem here is that my lecturer seems to be doing completely different things with every question and it's getting confusing.
So, I calculated the characteristic polynomial of the matrix, and got one
eigenvalue of t = 1.
So I'm now dealing with the matrix A - tI, in this case A - I.
rk(A - I) = 1, so dimKer(A - I) = 2.
(A - I)^2 = 0 = B
So rk(B) = 0, then dimKer(B) = 3
Continually raising the powers of A - I will results in 0, so the kernels of powers stabilize at the second step, so we should expect a thread of length 2.
The kernel of A - I is spanned by the vectors ( 3/2, 1, 0) and (-1/2, 0, 1)
I should be using columns instead of rows, but I don't know latex so this was the easiest way to write it. Just imagine they were written as columns..
Here's the main issue, when I find out what vectors span the kernel, and use those as columns of a new matrix, I then reduce that matrix to Reduced Column Echelon Form.
That's fine, but, in some of my lecturers examples he takes a vector corresponding to the missing leading one as a basis, and it others he takes one of the columns of the RCEF.
My question: why the differences and does it matter which of the columns are taken?
I'm lost. Can you please explain what to do, step by step?
Thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Jordan Normal Form / Jordan basis
Thread Forum Replies
Jordan Normal Form / Jordan basis Calculus & Beyond Homework 3
jordan basis and jordan normal form Calculus & Beyond Homework 12
Jordan Normal Form of Matrices Calculus & Beyond Homework 4
Jordan Normal Form Problem Calculus & Beyond Homework 0
Jordan Normal Form Linear & Abstract Algebra 2
