Spacecraft traveled into space from Earth
  • Context: High School
  • Thread starter Thread starter UrbanXrisis
    Earth Space Spacecraft
The discussion revolves around the concept of whether a spacecraft traveling into space from Earth could eventually reach the "other side" of the Earth, particularly in the context of the universe's topology and the implications of a closed universe.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant questions if a spacecraft traveling into space could ultimately reach the other side of the Earth, assuming it travels through the universe.
  • Another participant proposes that if the universe is topologically closed, similar to the Earth's surface, it might be possible to "wrap around" and return to the starting point after traveling in a specific direction.
  • Recent astronomical observations are mentioned as suggesting that the universe may not be closed, although specifics of these observations are not provided.
  • A later reply clarifies that it would be misleading to think of arriving at the "other side of the Earth," as the Earth's rotation would likely alter the position of any point of arrival during the journey.
Participants express differing views on the topology of the universe, with some suggesting it may be closed while others indicate that observations imply it is not. The discussion remains unresolved regarding the implications of these ideas on the original question.
The discussion does not resolve the assumptions regarding the universe's topology or the implications of Earth's rotation on the journey of a spacecraft.
UrbanXrisis
is it true that if a spacecraft travled into space from Earth, it will ultimately reach the other side of the Earth (supposing it travled though the universe)?
Astronomy news on Phys.org
It might eventually if our universe is topologically closed. Consider an analogy:
The Earth's surface is a 2 dimensional topologically closed surface. If you set out in a particular direction and travel far enough, eventually you'll go right round the Earth and end up back where you started.
Similarly, it is possible that our universe is a 3 dimension topologically closed space. If that is true, then if you travel out into space in a particular direction, eventually you will "wrap around" and end up back where you started.
Recent astronomical observations seems to suggest, however, that our universe is not actually closed.
What observations are those?
Notice by the way that it would be incorrect to think that you would arrive at the "other side of the earth". I feel sure that the time required to "circumnavigate the universe" (assuming such a thing is possible), the Earth would have rotated enough that you could might well arrive at any point!
12K
  • · Replies 28 ·
  • · Replies 66 ·
