Generalise the magnetic field of multiple current loops
The original poster attempts to determine an equation for calculating the magnetic flux density at the center of multiple current loops that encircle each other. The subject area involves electromagnetism, specifically the behavior of magnetic fields generated by current-carrying loops.
  • The original poster considers integrating the magnetic flux density equation over a range of radii but questions whether the magnetic fields can be added in this manner. Other participants discuss the need to account for the number of turns and suggest a different approach to the integration.
Participants are actively engaging with the original poster's attempts and providing guidance on how to approach the integration. There is a recognition of the need to clarify the mathematical setup, and some participants offer insights into how to correctly express the differential elements involved in the calculation.
The original poster expresses a lack of familiarity with using calculus for this type of problem, indicating a potential gap in understanding that may affect their ability to manipulate integrals effectively. There is also a mention of uniform distributions of loops being assumed in the discussion.
Orlando
Determine an equation to calculate the flux density at the center of a range of current loops encircling each other.
The equation for the magnetic flux density at the center of a current loop is
mu*I / (2*r)
I assumed I could just integrate the above equation over a range of radii as follows:
b
[tex]\int[/tex](mu*I / (2*r)) dr = (mu*I/2)*-ln(a/b)
a
Have I done this correctly or do the magnetic fields not add this way? Please help!
PS. How on Earth do you use the maths tools to write equations in these posts.
Besides dimensional incorrectness you should realize that the current that appears in the expression is [n*i] i.e the number of turns per unit length times the length. What you can do is write the current as n*dr where dr is differential radius.Then you integrate.You realize now that you can not expect integral of field times length to give you field.
Thank you for your response. I must apologise - I've never really learned how to use calculus in this manner and still don't quite understand. If it's not too much effort, could you write out the integral? I have run out of time and don't understand how to manipulate integrals. It would be much appreciated.
To write out any integral you first need to write your basic equation--which in this case is the B field at the centre of the loop--for a differential element.That element could be a small ring(differential radius),length(differential length),current element,mass element,etc.
In the formula for B field at the centre of the field the current appearing is actually differential--you would appreciate that it is only a small part of the total current.But the variable in your equation is radius r.So you manipulate element di as n*dr where n is the number of current loops per unit radius which in this case is N/b-a[N--total loops].Of course uniform distributions of loops is assumed.
Now you integrate accordingly.It can be easy if you always remember that the element of integration should come out of the basic equation.If you are adding it later it will be almost always wrong.
Ah, I understand it much better now. Thank you very much for your help, I appreciate it.
