Register to reply
How to calculate gravitational force?
by mdmaaz
Tags: gravity
Share this thread:
mdmaaz
#1
May10-11, 06:57 AM
P: 41
What is the formula for calculating the gravitational force between two objects of a given mass? It's a really simple question. But I'm just a thirteen year old who desperately wants to know.
Phys.Org News Partner Physics news on Phys.org
Mapping the optimal route between two quantum states
Spin-based electronics: New material successfully tested
Verifying the future of quantum computing
ZapperZ
#2
May10-11, 07:11 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,239
Please bookmark the Hyperphysics website.
http://hyperphysics.phy-astr.gsu.edu/hbase/grav.html
Zz.
mdmaaz
#3
May10-11, 07:23 AM
P: 41
Thanks, I can understand gravity so much more better now!
mdmaaz
#4
May10-11, 07:27 AM
P: 41
What do the letters in the formula stand for? Would really appreciate it if you tell me.
mdmaaz
#5
May10-11, 07:34 AM
P: 41
I know the formula for calculating the gravitational force between two masses. In the formula "G" means gravitational constant. The gravitational constant is 6.67E-11 m3 s-2 kg-1. But what does "6.67E-11 m3 s-2 kg-1 mean"?
I would really appreciate it if give me an example of calculating gravitational force between two objects.
Disconnected
#6
May10-11, 12:32 PM
PF Gold
Disconnected's Avatar
P: 110
Quote Quote by mdmaaz View Post
Hey, mdmaaz.
The units of the universal gravitational constant G, N m^2 kg^-2, N is shorthand for Newtons, the measure of force. m is for metre, kg is for kilogram. The units can sorta be thought as being the way they are due to the units of the other variables in the equation.
F(gravity) is the force due to the gravitation attraction between the two object. G is the universal gravitational constant. m1 and m2 are the masses of the two objects between which the gravity is acting (for example, between the earth and your body). r is the distance separation between the two objects (notice that earth pulls on you much more then saturn does, despite saturn's much larger mass!) .
Here is a quick example of finding the gravitational force between two objects.
Let's say that object 1 has mass m1=10kg and that object 2 has mass m2=25kg. If they are 10m apart, then the force is given by (from hyperphysics)
F=(6.67*10^-11*10*25)/10^2
F=1.668*10^(-9)N
mdmaaz
#7
May12-11, 08:17 AM
P: 41
Thanks "Disconnected"! You're awesome dude. I can finally understand how to caclulate gravitational force.
Register to reply
Related Discussions
Calculate the net force pulling on Earth with phases of Moon(Gravitational Force) Introductory Physics Homework 4
How does light bend under gravitational field(gravitational force), why? Special & General Relativity 2
Calculate acceleration after getting the Gravitational force between two bodies General Physics 1
Free body diagram involving normal force, gravitational force, and applied force. Introductory Physics Homework 4
Gravitational Force, the derivative of Gravitational Potential Energy? Classical Physics 3
