Rate of flow of water through a pipe
The discussion centers on the relationship between motor power and the rate of water flow through a horizontal pipe. The original power required by the motor is expressed as P = ρAv²*v, where A is the cross-sectional area and v is the velocity of water flow. To increase the flow rate by a factor of n, the power must increase to P1, which is determined to be P1 = n³P. The conclusion drawn is that the ratio of P1 to P is n:1, confirming the correctness of the solution presented.
  • Understanding of fluid dynamics principles
  • Familiarity with the equations of motion for fluids
  • Knowledge of power calculations in mechanical systems
  • Basic grasp of cross-sectional area and velocity relationships
  • Study the principles of fluid dynamics in detail
  • Learn about the Bernoulli equation and its applications
  • Explore the relationship between power and flow rate in hydraulic systems
  • Investigate the effects of pipe diameter on flow velocity and power requirements
Students in engineering, particularly those studying fluid mechanics, as well as professionals involved in hydraulic system design and analysis.
zorro
A motor of power P is used to deliver water at a certain rate through a given horizontal pipe. To increase the rate of flow of water through the same pipe n times, the power of the motor is increased to P1. The ratio of P1 to P is?
Let the velocity of flow of the water be 'v'.
The power required by the motor P = ρAv2*v, where A is the area of cross section of the pipe. Rate of flow of water, R = Av
P=ρRv2=ρR3/A2
It can be seen that P1=n3P.
The answer given is n:1
What's wrong?
I think there is nothing wrong with your solution :)
Thanks!
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 16 ·
