Evaluating Int. on V Along C Using Greens Theorem
The problem involves evaluating a line integral of a vector field V along a closed path C defined by the equation x² + y² = 1, using Green's Theorem. The vector field is given as V = (3y² - sin(x)) i + (6xy + √(y⁴ + 1)) j.
  • The original poster attempts to apply Green's Theorem but expresses difficulty with determining the limits of integration. They consider converting to polar coordinates but find it complicated. Other participants suggest rechecking the integrand and hint at the geometric interpretation of the closed path.
Some participants have provided hints regarding the limits of integration and the nature of the vector field. There is an ongoing exploration of whether the force represented by the vector field is conservative, with references to the implications of Green's Theorem and the conditions for a force to be considered conservative.
Participants are discussing the implications of the integrand and the conditions under which the integral evaluates to zero, as well as the relationship between conservative forces and line integrals over closed paths.
imagemania
V = (3y^2 - sin(x)) i +(6xy+√(y^4+1))j along the closed path C defined by x^2 + y^2 =1, counterclockwise direction
Greens Thoerem
I am stuck on the limits part of the integration. I get so far into greens theorem to obtain:
∫∫ [6y√(y^4+1) -6y].dx.dy
But unsure how to go beyond this, i can't see any clear x or y limits. I could convert into polar, but that also looks very messy.
Any help/point in the right direction will be appreciated!
Recheck your integrand. It looks complicated because you made a mistake.
The limits should be straightforward to get. Hint: What shape does the equation x2+y2=1 define?
Ohh i see where i made the mistake. I now get within the integral 6y - 6y = 0.
Is this correct?
Yup. You could always do the line integral to verify. :)
I've just thought, if you had any path then, regardless of its involvement, this must always be zero if the force is still the same. Take the same force and the equation xi + cos(x) j clockwise and x ≤ |π/2 |and y = 0.
If this is true and any path results in zero work done, then do we simply call this a conservative force?
Green's theorem is a special case of Stoke's theorem, which says
[tex]\int_S (\nabla\times \mathbf{F})\cdot d\mathbf{A} = \oint_{\partial S} \mathbf{F}\cdot d\mathbf{r}[/tex]
A conservative force satisfies ∇xF = 0, so the integral around any closed path will be 0. In this case, by applying Green's theorem, you found ∇xF does indeed vanish, so yes, it's a conservative force.
Note you can also look at this problem as being of the form ∫ (M(x,y) dx + N(x,y) dy). Since you had ∂M/∂y = ∂N/∂x, the integrand is an exact differential, meaning you can, in principle, find a function Φ(x,y) such that dΦ = M(x,y) dx + N(x,y) dy. The function Φ is the potential energy function (to within a minus sign), which, again, exists because F is conservative.
