Check Linear Dependence/Independence of Vectors Without Calculator
This discussion focuses on determining the linear dependence or independence of a set of vectors without using a calculator. The primary method discussed involves constructing a matrix from the vectors and calculating its rank. If the rank equals the number of vectors, they are linearly independent; if the rank is less, they are dependent. The discussion clarifies that this method applies regardless of the number of vectors relative to the dimension, although having more vectors than dimensions guarantees dependence.
  • Understanding of linear algebra concepts, specifically linear independence and dependence
  • Familiarity with matrix rank and its implications
  • Basic knowledge of vector spaces and dimensions
  • Ability to visualize vectors in n-dimensional space
  • Study the concept of matrix rank in detail, including methods for calculating it
  • Explore graphical representations of vectors in 2D and 3D to understand dependence visually
  • Learn about the implications of vector spaces and dimensions in linear algebra
  • Investigate alternative methods for checking linear dependence, such as using determinants for square matrices
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators seeking effective methods to teach vector independence concepts.
aliaze1
Does anyone know a good way to check if a given set of vectors (assume we just know we have a set, not their values) is linearly dependent or linearly independent without a calculator?
Ex: Given a set of n-dimensional vectors, say, vector1, vector2, and vector3, how would one determine if these vectors are linearly independent or dependent?
If I were to take the transpose of these vectors and make them into a matrix, and find the rank of this matrix, then I could perhaps check? If rank = number of vectors that make that matrix, then I have linear independence. If rank = less than number of vectors that make the matrix, then I have dependence (please correct me if I am wrong). I am a bit confused, as I know that the dimensions given (n) matter. If number of vectors is same as n/not same as n, does that make a difference?
Is there a better way of doing this? Graphically? Way to do this without looking at rank?
This is correct. Just put the vectors in a matrix and calculate the rank. The rank is the maximal number of linear independent vectors. Thus if the rank = number of vectors, then you have independence, otherwise, you have dependence.
Also, there is no need to take the transpose of the matrix. The rank of a matrix equals the rank of the transpose.
No, the above procedure will work for any number of vectors. Note that the rank is defined for any matrix, not just square matrices!
But of course, if you have more vectors than your dimension, you will always have dependence! The rank of that matrix will also give you this.
I think this is the best way of doing this. You can always draw the vectors and see whether they are dependent, but that becomes rather inconvenient if your dimension exceeds 3...
  • · Replies 19 ·
  • · Replies 23 ·
