Line Integral, Green's Theorem
The problem involves evaluating a line integral and a double integral using Green's Theorem, specifically for a region defined by the curves y=x^2 and y=4. The original poster expresses confusion regarding the setup and evaluation of the line integral, particularly due to the lack of a straightforward parameterization.
  • Participants discuss splitting the line integral into segments along the curves y=4 and y=x^2. There are questions about the correct limits of integration and the implications of integrating along a path versus over an area.
Some participants have offered guidance on how to approach the line integral and the importance of the direction of integration in relation to Green's Theorem. There is an ongoing exploration of the correct setup for the integrals, with some participants questioning the results obtained and the reasoning behind them.
The original poster mentions a lack of textbook resources and insufficient coverage of the material in lectures, which may contribute to the confusion regarding the problem setup and integration techniques.
Angello90
[tex]\int_{C} (xy^{2}-3y)dx + x^{2}y dy[/tex]
G is finite region enclosed by:
[tex]y=x^{2}[/tex]
[tex]y=4[/tex]
C is boundary curve of G. Verify Green's Theorem by evaluating double integral and line integral.
The attempt at a solution
[tex]Q = x^{2}y[/tex]
[tex]dQ/dx = 2xy[/tex]
[tex]P = xy^{2}-3y[/tex]
[tex]dP/dy = 2xy-3y[/tex]
Limits to integral are:
[tex]from x = - \sqrt{y} to \sqrt{y}[/tex]
[tex]from y = 0 to 4[/tex]
Thus integral is:
[tex]\int_{G} dQ/dx - dP/dy dA = \int_{G} 3 dA[/tex]
Therefore Green's Theorem gives me: 32
How the hell do I do Line integral? Spend entire day looking it up, but examples on internet uses C which is given in a nice polar form. Where in here I don't have such a nice form - I think. I would assume that dy = 4 (from 0 to 4) but than I don't know what would be dx.
Simply confused! Any hints guys?
Thanks
Angello
Hmm, what I would do here is split the integral into two, the part along y=4 and the part along y=x^2, For the line y=0, the line integral would transform into dy=0 and so:
[tex] \int_{C} (xy^{2}-3y)dx + x^{2}y dy=\int_{-2}^{2}16x-12dx[/tex]
Likewise for the other part of the integral, use y=x^2 and hence dy=2xdx
Ok. Could you explain that slower? So it's like, you find area under the rectangle x = -2,2 y= 0,4, and than the area under the paraboloid y=x^2 again from x= -2,2 and y= 0,4. Than subtract both answers?
No, there is no "area" involved- you are integrating along a path, not over a region.
To integrate f(x,y)dx+ g(x,y)dy over a path given by x= u(t), y= v(t), [itex]a\le t\le b[/itex], You determine that dx= u' dt and dy= u' dt so that your integral becomes
[tex]\int_a^b f(u(t), v(t))u'(t)dt+ g(u(t),v(t))v'(t)dt[/tex]
I am sure that is what the examples you saw did. (You say you found them on the internet. Does your textbook not have examples? Not to mention a definition of "path integral".
The examples you saw did NOT use polar coordinates as you seem to think. I suspect that the path was a circle or part of a circle so they use the "standard" parameterization for a circle with radius R, centered at the origin, x= cos(t), y= sin(t).
As HallsofIvy has said, you're integrating along a path, the path i presented to you was the path y=4, you have to find where that intersects with the other path, so you set x^2=4 which shows that the intersection points are -2 and +2. So you substitute y=4 and dy=0 in your contour integral to get the integral along that particular segment of the path.
I don't have any textbook, just lectures notes, who didn't cover the material, as he was sick, but still expect us to know it.
Ok so in my case I have one path which can be split into two, the paraboloid path y=x^2 and line y=4 yes? Than I just add both?
But I get different answer. The path y=4 I get:
[tex]\int_{C} (xy^{2}-3y)dx + x^{2}y dy=\int_{-2}^{2}16x-12dx = -48[/tex]
And for y=x^2; dy=2xdx
[tex]\int_{C} (xy^{2}-3y)dx + x^{2}y dy=\int_{-2}^{2}x(x^{2})^{2}-3(x^{2})dx + x^{2}(x^{2})2xdx = \int_{-2}^{2}3x^{5} - 3x^{2} dx = -16[/tex]
I should add them but this gives me -64. Why is that? Should I get 48 rather than -48. Than I would get 32, as Green's result.
Be careful about the direction of integration. Green's theorem requires that you integrate around a closed path counter-clockwise. On the parabola, that means you are integrating from x= -2 to x= 2, but on the line y= 4, to complete the path, you have to go from x= 2 to x= -2, reversing the sign of the integral.
You have to integrate from 2 to -2 on your second integral as you're integrating around a path...
So the total integral should be -48+16=-32. If you integrated in the opposite direction (I did clockwise) then your answer would have become 32.
That's what I was thinking. Was confused cause it is usual donated it by
[tex]\oint[/tex]
isn't it? Thanks a million guys! So it turns out to be fairly simple example!
Cheers
Angello
It is, I use this notation when I write countour integrals down, and it is a more applied mathematicians approach, the pure mathematician will just write it as your teacher did.
Glad we could be of help.
  • · Replies 25 ·
  • · Replies 16 ·
