| New Reply |
Sum of Dice Rolls |
Share Thread | Thread Tools |
| May14-11, 06:20 AM | #1 |
Sum of Dice Rolls
There is a 5-sided fair dice with faces showing 1, 2, 3, 4, 5 dots. The dice is rolled four times. Find the probability of getting a total score between 10 and 15 (inclusive). 2. Relevant equations If X is the score from one roll, then it follows a discrete uniform distribution with parameter 5. 3. The attempt at a solution I'm really clueless as to how to start. I can only think of writing out all the possible sums and finding the probability. But that seems rather tedious, is there a better way? |
| May14-11, 03:53 PM | #2 |
Recognitions:
R.G. Vickson |
| May15-11, 06:04 AM | #3 |
Ok, what I did was to draw out two tables. The first one is here:
1st Dice 1 2 3 4 5 2nd 1 2 3 4 5 6 2 3 4 5 6 7 3 4 5 6 7 8 4 5 6 7 8 9 5 6 7 8 9 10 If Y = X1 + X2 So P(Y = 2) = 1/25 = P(Y=10), P(Y=3) = 2/25 = P(Y = 9), P(Y=4) = 3/25 = P(Y=8), P(Y=5) = 4/25 = P(Y=7), P(Y=6) = 5/25. Then I drew out another table, since the total T = Y1 + Y2, where the row and column headers are from 2 to 10, and I wrote the probability next to each of them. Then I found all the possible sums and added it all up one by one. The answer I got was 433/625 = 0.6928 But that's really tedious and I hope to learn a better way :) |
| May15-11, 12:26 PM | #4 |
Recognitions:
Sum of Dice RollsThis is still tedious, but we can approach it recursively: we have a product f(z)*[f(z)*f(z)*f(z)]. Each factor contributes to z^i. In fact, if we have z^j1 from factor 1, z^j2 from factor 2, etc., the total is z^(j1+j2+j3+j4), so we need j1+j2+j3+j4=i. The coefficient of z^i is the total number of combinations {j1,j2,j3,j4} that sum to i; call it N4[i]. How can we get N4[i]? Well, if the first factor contributes z^j the remaining three must contribute i-j, and the number of these is N3[i-j]. Each j makes such a contribution, so the total is N4[i] = sum{N3[i-j], i=1..5} for i >= 8, while N4[i] = sum{N3[i-j], j=1..min(5,i-3)} for i = 4, 5,6,7. So, if we know N3[k] for k=3,...,15 we can get all the N4[i]. Similarly, N3[i] = sum{N2[i-j],j=1..min(5,i-2)} for i = 3, ..., 15, etc. These are most straightforward if we just let N1[i] = 0 for i <= 0 and for i >= 6. Then N2[i] = sum{N1[i-j] ,=1..5} holds for all i. Then we let N2[i]=0 for i <= 1 and for i >= 11. This lets us write N3[i] = sum{N2[i-j]. j=1..5} for all i, etc. To do this by hand is reasonably straightforward but somewhat tedious, although less tedious than other methods. It can all be done effortlessly in a spreadsheet, for example. RGV |
| May15-11, 04:07 PM | #5 |
I would sure like to see a picture of this "5-sided fair die".
| May16-11, 09:38 AM | #6 |
Thanks Ray for the help, I'll try to understand it :) |
| May16-11, 12:41 PM | #7 |
Ray, please be advised: we do not do homework for people here. We guide them the answer.
I was thinking the same thing but it's not hard to do. A fair die does not have to be a regular polyhedron. You can make a fair die of any number from 2 to theoretically infinite. Start with a prism with the requisite number of sides and just round off the ends. The die can only come to rest in one of five equally likely configurations. |
| New Reply |
| Thread Tools | |
Similar Threads for: Sum of Dice Rolls
| [SOLVED] Number of rolls with m many n-sided dice | Calculus & Beyond Homework | 9 | ||
| Dice rolls | Set Theory, Logic, Probability, Statistics | 3 | ||
| Sum of multiple dice rolls | Set Theory, Logic, Probability, Statistics | 2 | ||
| Variance of 36 standard dice rolls | Introductory Physics Homework | 1 | ||
| Dice rolls | General Physics | 4 | ||
