Mk
- 2,040
- 4
What is quantum spin? I've read lots of things about it and describing it, I still don't quite understand it.
The discussion revolves around the concept of quantum spin, exploring its definition, implications, and the mathematical framework surrounding it. Participants share various perspectives on how quantum spin differs from classical notions of rotation, its representation in quantum mechanics, and its relationship with quantum field theory.
Participants express a range of views on the nature of quantum spin, with no clear consensus reached. While some agree on the abstract nature of spin, others highlight its mathematical and physical implications differently, leading to ongoing debate.
Some discussions touch on the limitations of classical analogies in understanding quantum spin and the complexities of its mathematical representation, but these remain unresolved within the conversation.
This discussion may be of interest to students and enthusiasts of quantum mechanics, particularly those seeking to understand the nuances of quantum spin and its implications in both theoretical and experimental contexts.
Fredrik said:In quantum mechanics, the states of a physical system are represented by rays in a complex Hilbert space. A ray is a subset of the Hilbert space that consists of vectors that "point in the same direction, but may have different lengths". If x is a vector and c a complex number, x and cx belong to the same ray.
Fredrik said:Different observers would use different rays to represent the same state. E.g. if I'm using a wavefunction that represents a particle localized somewhere on my right (positive x axis), an observer that is rotated 180° will use a wavefunction that represents a particle localized somewhere on his left (negative x axis) to describe the same particle.
It is possible to define a function T that takes each ray that I would use to describe a system, to the ray that the rotated observer would use. If I say that the system is in the state represented by ray R, the rotated observer would say that the system is in the state represented by ray T(R). Let's call a function defined in this way a "symmetry transformation".
There's a theorem that was proven by Eugene Wigner, that says that it's possible to define a function U from the set of symmetry transformations into the set of operators on the Hilbert space, such that each U(T) is either linear and unitary or antilinear and antiunitary.
It is natural to assume that there exists a symmetry transformation for each member of the rotation group SO(3). When we do, Wigner's theorem leads us to the concept of spin.
A rotation can be parametrized by three numbers (e.g. Euler angles). Let's use the greek letter θ to represent these parameters, and let X(θ) be the rotation operator on [tex]\mathbb R^3[/tex] that corresponds to the parameters θ. Let T(X(θ)) be the symmetry transformation that corresponds to that particular rotation. Wigner's theorem tells us that there must exist a linear and unitary operator U(T(X(θ))), which I will write simply as U(θ) from now on, that tells us what vector a rotated observer would use to represent the same state. If I say that the state is represented by a ray that contains the vector x, the rotated observer would say that the state is represented by a ray that contains the vector U(θ)x.
The spin operators show up when we Taylor expand U(θ). The result of a Taylor expansion can be written as
[tex]U(\theta)=1-\frac{i}{2}\sum_{i,j}\omega_{ij}J^{ij}+\dots[/tex]
where the J's are hermitean operators, the omegas are real numbers (that depend on θ), and the second and higher order terms have been omitted. J and omega are both anti-symmetric:
[tex]\omega_{ij}=-\omega_{ji}[/tex]
[tex]J^{ij}=-J^{ji}[/tex]
The zeroth order term is the identity operator on the Hilbert space if we choose to use parameters that have the property that X(0) is the identity operator on [tex]\mathbb R^3[/tex].
Since J is anti-symmetric, it only has three independent components. These can be identified with the spin operators:
[tex]J^1=J^{23}[/tex]
[tex]J^2=J^{31}[/tex]
[tex]J^3=J^{12}[/tex]
It can be shown that the properties of the rotation group SO(3) imply that these three operators must satisfy the commutation relations
[tex][J^i,J^j]=i\sum_k\epsilon_{ijk}J^k[/tex]
(If you're not used to the epsilon notation, you may not recognize that these are the commutation relations for spin operators that you've seen lots of times before, but they are).
It should be clear from the above that spin is a quantum mechanical property that isn't easily explained in plain english. It should also be clear that spin is a property that is very closely related to rotations. One more thing that indicates this is that the orbital angular momentum operators defined by
[tex]\vec L=\vec x\times\vec p[/tex]
satisfies the same commutation relations as the spin operators.
Fredrik said:I think the term is "unit ray", not "unitary ray". At least that's what Steven Weinberg calls it in "The quantum theory of fields", volume 1. It doesn't really matter if you say that "states are represented by rays" or "states are represented by unit rays", since there's exactly one "ray" for each "unit ray" and vice versa.
zefram_c said:Not to contradict anything already said, but spin behaves in many ways as angular momentum. By that I mean that it is conserved as part of total angular momentum whenever an electron interacts with a photon or some other particle. Also its natural unit (Planck constant) carries dimension of angular momentum. Going back to the electron, it is indeed wrong to picture it as being in some rotation state - the way I think about it is that electrons (and other particles as well) have some internal degree of freedom that manifests itself like angular momentum in terms of quantization / projection.
