| New Reply |
Circuit problem with ammeter and unknown resistance |
Share Thread | Thread Tools |
| May18-11, 12:08 AM | #52 |
| May18-11, 07:01 AM | #53 |
I agree that equation 1 with I0, I1 and I2 is unneeded. It appears to just overcomplicates things to add I0 to the equation.
I am now considering just 4 equations then. It looks like it takes a bit of work to solve it. I'll have some college time this evening so I'll post back later my results. Sorry I am procrastinating with this, but I am really enjoying myself working on this exercise and I wanna take my time and do it right and get to the right conclusions. Had a bit of insomnia lately due to my new job bumping in with school and helping other students, so couldn't get to it. :( |
| May18-11, 08:29 AM | #54 |
What I mean about "grounding a point" is that you'll later find that when people design circuits they often times have one reference point from which all other voltages are referenced, and this point is said to have 0 volts (0 is really arbitrary if you think about it because we are really just doing a potential difference, but it makes sense because you don't 5-0 is more trivially 5 than if we gave ground 1V and were subtracting one all the time; e.g. 6-1). This point is usually tied to earth, the earth ground is kind of the ultimate reservoir of electrons, but is sometimes simply tied to chassis of a box (or is sometimes just a "signal ground" on the plane of a PCB). I didn't really want to go searching for a reference that had just the right information, so you'll have to take it from me, a lowly physicists who think he knows circuits well :p. In your circuit you can pick any point from which all other points would be referenced. Point C really makes the most sense to ground, and give zero potential.
Oh right, and the garden hose analogy. Since current is a flow, and water is a flow that's where the analogy begins. You can control the water flow by turning a spigot, analogous to voltage. Certain things, like gravel, may impede water flow just like resistors. The only thing is that I haven't really come up with an example of a water capacitor. As for gneill's initial advice, which I was soon to echo after having read through the topic, let's address it now: ILS, I agree that there a couple ways to solve this problem, and I fully embrace eventually tackling an alternate solution. I do, however, disagree with starting with the hardest. :p Mind if I quickly outline our a more practical approach? Also, didn't there used to be letters on your diagram? Let's do some KVL since that's how you started. Make both loops CCW, just to demonstrate that it will work. Right loop: Irht*Rx+Irght*R2+Vs=0 Left loop: Ilft*R1+Ilft*R3-Vs=0 Now for the constraint from the problem: We know that there is no current flowing through the ammeter, which means that the leftmost point and the rightmost point are at the same potential -Irht*R2=Ilft*R1 (you could have also used the voltage loop if what I did was confusing, going CW Irht*R2+Ilft*R1=0) So, now there are 3 eqns and 3 unknowns, wahoo! Note: for the constraint you could also do the other voltages, -Irht*Rx=Ilft*R3. There's other tricks that you could use to solve this problem really quickly. If you treat the leftmost point and rightmost point as voltage dividers (look it up if you haven't seen it), you just equate them and you get the answer presto, virtually no work involved! Sorry if I stole anyone's thunder, but the amount of complexity in this problem was getting a bit absurd, beyond being practical for learning I felt. |
| May18-11, 12:13 PM | #55 |
![]() I recognize the characters and have rudimentary vocabulary from self-study אולפן. But in this case, google translate came to the rescue. (caveat: for those wanting to try this, it requires setting up your keyboard for Hebrew. However, do this at your own peril , an accidental keystroke can suddenly change your keys from Latin to Hebrew and you'll spend the next hour trying to change it back.In fact, it is a good idea to solve these exercises using at least one more method. If you arrive at the same answer, there is a high likelihood your solution is correct. (ILS also alludes to this in step 4 of his last post). |
| May18-11, 11:34 PM | #56 |
Hmm...does there have to be a point in a circuit that has 0 V potential? |
| May18-11, 11:44 PM | #57 |
Recognitions:
You seem to have missed my last reply (2 equations!): http://www.physicsforums.com/showpos...4&postcount=50 |
| May18-11, 11:45 PM | #58 |
Sorry, I lost the thread of this thread!
My worst pun to date ;) I'll get to it and post back |
| May18-11, 11:48 PM | #59 |
| May18-11, 11:49 PM | #60 |
Recognitions:
Just try it! [edit] (You procrastinator you! ) [/edit]
| May19-11, 12:16 AM | #61 |
| May19-11, 12:17 AM | #62 |
| May19-11, 12:18 AM | #63 |
Recognitions:
| May19-11, 12:30 AM | #64 |
Recognitions:
| May19-11, 12:37 AM | #65 |
| May19-11, 12:39 AM | #66 |
Recognitions:
Why minus??????????!!!!!!!!!!!!
ehild |
| May19-11, 12:40 AM | #67 |
My bad, discount the minus. I was excited I was getting somewhere :P
Rx = R3R2/R1 Is that right? |
| May19-11, 12:45 AM | #68 |
Recognitions:
![]() Wait! Sorry! No it is a mock! ![]() I was just wondering how Rx could be negative. What could it mean? Did you just discover negative resistors? But that's great! We could generate voltage out of nothing!!! ![]() With the method we used, we did introduce 1 unknown to many, but it didn't matter, because it would cancel out. |
| New Reply |
| Thread Tools | |
Similar Threads for: Circuit problem with ammeter and unknown resistance
| Resistance of ammeter and voltmeter | Introductory Physics Homework | 14 | ||
| Finding an unknown resistance in an Electric Circuit | Introductory Physics Homework | 1 | ||
| ammeter and voltmeter resistance | Engineering, Comp Sci, & Technology Homework | 6 | ||
| RC Circuit/Current/Resistance Problem. Circuit Gurus come here! | Introductory Physics Homework | 15 | ||
| Internal resistance of an ammeter | Engineering, Comp Sci, & Technology Homework | 3 | ||
