| New Reply |
Volumetric Humidity at given Temp and Pressure? |
Share Thread | Thread Tools |
| May15-11, 01:04 PM | #1 |
1. The problem
I need some help in a car tuning project I'm doing, please! I have a turbo charged engine and I have fitted water injection to cool the air charge entering the engine. The idea being that cooler air is more dense and allows more fuel to burn. I need help to calculate the maximum amount of water that can be evaporated into the air charge before exceeding 100% saturation. Clearly if I inject more water than can evaporate it will displace air in the engine cylinder. So in this case it is a 2,000cc engine, and without any water injection the intake air is at a pressure of 1.65Barg (relative to atmosphere) and a temperature of 130C. How much volume of water can be evaporated into the 2,000cc volume filled with air at these conditions? 3. The attempt at a solution If I understand correctly then 100% relative humidity is the amount of water that can be evaporated in a set volume of air at a given temperature. So I found a table showing that 100m3 of air at a temperature of 20oC reaches 100% humidity with 1740cc of water. So if we increase the air pressure by 1.65Bar, we should reach 100% humidity with (1740cc/1.65Bar) 1050cc of water. An air volume correction factor for temperature can be applied. Every 10oC increase in temperature increases the air volume by a factor of 1.04. However, volume is fixed here, so air density is decreased by the same. Air temp increases by 110oC so (11 x 0.04 = 0.44) the water that can be evaporated should increase by 1.44. (1050cc x 1.44) 1510cc of water per 100m3 at 100% humidity. 100m3 = 100,000L 100,000L / 2 = 50,000 1510cc / 50,000 = 0.0302cc of water can be evaporated in a 2,000cc volume of air at 1.65Barg and 130C. Is this correct?! What do you think? References Relative Humidity of Air at given Temp - http://www.engineeringtoolbox.com/st...air-d_260.html Air Volume Correction Factor at given Temp - http://www.engineeringtoolbox.com/ai...ume-d_853.html |
| New Reply |
| Thread Tools | |
Similar Threads for: Volumetric Humidity at given Temp and Pressure?
| Atmospheric Density from: Alt, Temp, Pressure & Humidity | Introductory Physics Homework | 2 | ||
| Calculating Density Alttitude of Air knoing temp/baro/humidity? | General Physics | 3 | ||
| How pressure and temperature affects volumetric flow? | Classical Physics | 6 | ||
| temp of co2 under pressure | General Physics | 2 | ||
| temp. and air pressure | General Physics | 6 | ||
