Determining concentration by measuring pressure change
The discussion focuses on deriving an equation to calculate concentration from pressure change in a known volume, utilizing the ideal gas law (pV = NkT) and mass volume rate (Q = Fp = d(pV)/dt). The user attempts to manipulate the equations but struggles to arrive at the correct concentration value, indicating a potential misunderstanding of the relationship between the number of molecules and concentration. The key takeaway is that dividing by the known volume V is essential to convert the number of molecules into concentration, which the user initially overlooked.
  • Understanding of the ideal gas law (pV = NkT)
  • Familiarity with mass volume rate (Q = Fp = d(pV)/dt)
  • Basic knowledge of calculus for differentiation
  • Concept of concentration in terms of number of molecules per volume
  • Study the derivation of the ideal gas law and its applications
  • Learn about volumetric flow rate and its impact on concentration calculations
  • Explore advanced calculus techniques for manipulating differential equations
  • Investigate methods for measuring concentration in gas systems
Chemistry students, chemical engineers, and researchers involved in gas concentration measurements and related calculations.
Boltzano
Derive an equation how one can calculate concentration by measuring pressure change in a known volume.
Known data:
Pressure change dp/dt in a known volume V, volumetric flow rate F, total pressure p and temperature T.
Probably ideal gas law pV=NkT and mass volume rate (throughput) Q=Fp=d(pV)/dt
Not really sure how to solve this since this was not an textbook question but actual measurment so I'm not sure about the needed equations. But I would start:
d(pV)/dt=V*dp/dt=Q=Fp (since V is constant)
=> V*dp/dt=(Nkt/p)*(dp/dt)=Fp
=>N=(Fp^2/kT)*(dt/dp)
But doing so I end up with number of molecules and not concentration. This could easily be solved by dividing with known volume V but for some reason I won't get right numerical concentration (in measurments computer program calculated the concentration automatically from known data).
Was there some information missing or is this just too simple so people won't bother =D
Somehow my solution just doesn't seem right. Is it ok to take out the V from d(pV)/dt and then substitute with NkT/p?
