| New Reply |
Radiation free blast? |
Share Thread | Thread Tools |
| May17-11, 06:03 PM | #1 |
As I understand it there is little difference between a Hydrogen bomb and an atom bomb, but its the Nuclear option which causes the long term affects. So, why did governments move to Nuclear bombs over these other ones?
Also, can it be that the old ones are better, made to not emit radiation, nothing long lasting anyway? |
| May17-11, 06:27 PM | #2 |
Admin
Some atomic bombs can be 'boosted' by applying an appropriate neutronic fusion reaction. Hydrogen bomb = thermonuclear bomb (usually DT), but not all thermonuclear/fusion systems are hydrogen. Nuclear blasts are not radiation free. The basic reactions determine the proportion and spectra of neutrons and photons. A strong neutron flux will activate fallout. |
| May18-11, 02:59 PM | #3 |
The Starfish Prime (thermonuclear warhead) 1.4 Megaton test, at about 400 km altitude, created a lot of electromagnetic interference (EMP), beautiful auroras, but negligible radioactivation and fallout. See
http://en.wikipedia.org/wiki/Starfish_Prime Bob S |
| May19-11, 08:47 AM | #4 |
| May19-11, 09:06 AM | #5 |
Starfish Prime created a powerful man-made radiation belt that crippled a lot of satellites. "Fallout" is activated topsoil from an earth-based nuclear blast and so isn't really applicable to a space-based event, but there was plenty of radiation to go around.
| May31-11, 06:55 PM | #6 |
Thanks for the info, I've been reading up on what you said. Well, I'm a little more clued up but I didn't know that we could achieve fusion, I thought that is what they were trying to do in the US/UK with lasers to start the process and with helium3 in France. Still, that's not my point. What I'm still after is to know if, using something like a kilotonne (A-bomb) could the radiation that is harmful for humans and the environment be stopped, but of course still with the same effect of a blast. I expect an H-bomb would not be able to do this, but I don't know? Can an A-bomb, without increasing in size, start to approach megatons, that is unless an h-bomb can be tamed and so no more harmful than exploding TNT itself? I am under the impression that if TNT (in the thousands of tonnes) were to be detonated, you'd achieve the yield but withouth the radiation, but of course this would be hugely impractical. |
| May31-11, 09:06 PM | #7 |
An A-bomb can't approach megatons without being really big. Too big.
An H-bomb won't produce less fallout. Mainly because it has an A-bombis side as the trigger as noted. If somehow you could detonate the core of an H-bomb without using an A-bomb or the plutonium booster rod, you'd still create radioactive fallout from the matter around the fusion capsule and the gasses in the atmosphere. |
| Jun1-11, 05:55 AM | #8 |
A pure fusion device might neutron activate some of its casing, but that would be minor compared to the fission debris from a regular weapon. Some radioisotopes might be made from atmospheric gases, but that wouldn't be fall-out as such. It'd disperse too far and wide to be hazardous too. |
| Jun1-11, 06:07 AM | #9 |
Aside from an Atom or Hydrogen bomb I was looking into a Neutron blast, which is the opposite of what I'm researching into. However the design of it is such that the destructive radiation that does the damage to humans is for the purpose of removing them, leaving the area largely intact. So this must mean the radiation is shot lived, where as with nuclear its nocking around for some 700m years.
The air as I understand it does much of the buffering, to stop the radiation leaking from the blast zone. However the A bomb on Japan hasn't left any long lasting radiation, except in people. So its the H-bomb that is the problem, while the a and n do what they do, its only really instantly and for a short period this occurs for. Has anybody got some figures on the longevity of the radiation fall out for these bombs and how far the radiation travels? I understand the N bomb is somewhat safer than the a because the radiation is absorbed, but doesn't linger? Clarification would be goo thanks. |
| Jun1-11, 09:01 AM | #10 |
It is possible to make nuclear weapons that would generate much less fallout than the weapons deployed in militaries today. The reason for the US and Russia deploying these "dirtier" bombs is that for a given weight they were able to make a more destructive "dirty" bomb. A "clean" bomb of the same weight would have had less yield. http://en.wikipedia.org/wiki/Nuclear...gn#Clean_bombs
| Jun2-11, 10:36 PM | #11 |
A pure fusion warhead would release far less radioactive material, as the main product of fusing tritium and deuterium is simply Helium, which is not radioactive whatsoever. However, each reaction also releases a high energy neutron. These neutrons are uncharged and therefore they are very very hard to stop compared to other forms of radiation.
A neutron bomb is known as an Enhanced Radiation Weapon: An ERW is a fission-fusion thermonuclear weapon (hydrogen bomb) in which the burst of neutrons generated by a fusion reaction is intentionally allowed to escape the weapon, rather than being absorbed by its other components. The weapon's X-ray mirrors and radiation case, made of uranium or lead in a standard bomb, are instead made of chromium or nickel so that the neutrons can escape. NORMALLY these neutrons would be captured by uranium that surrounds the fusion core. These neutrons cause a huge fission chain reaction that release much more energy than a simple fission type weapon. MisterX is correct in that we don't use them because for the same size, the yield is much less. But this was back in the cold war where the effects of radiation and fallout were much less known. And arguably more accepted. |
| Jun3-11, 05:38 AM | #12 |
So it seems that at the time they could have researched such a radiation free bomb, they decided not to. Although Fusion as I understand it plays a big part in achieving this. I read a little into fourth generation bombs that are sub WMD, these then if used would surely have to be radiation free? and those are being research right now. |
| Jun3-11, 06:01 AM | #13 |
So if a bomb was purely Fusion (I don't know if we know how to make a 100% Fusion device), it had a lead jacket (not Plutonium - doesn't that cause trouble?) there would be no long lasting radiation like with a nuclear bomb? In fact wasn't that the bomb dropped on Hiroshima? I understand that such a bomb is not big enough and so that's why we use Fission and Neutron versions, but then the physical size of the bomb need just be made bigger? Surely advances have come along to make them smaller, I think I read the first bomb weighed in at 70 tonnes? And that's the thing isn't it, the "decay mechanisms" because this all happens in an instant, it's that which can't be modelled so easily. So the Neutron bomb destroys less buildings but removes the inhabitants, while being absorbed (can I say) harmlessly into the air for the most part but for the unknown reactions that occur. How long lasting is that radiation? |
| Jun3-11, 11:51 PM | #14 |
| Jun4-11, 08:52 AM | #15 |
What I mean by a clean bomb is that presently with the choice of Nuclear the area it's deployed on is not the only area affected. Where as clean, to me, would be the containment of the radiation to that area, with anything swept via the winds dissipating to harmless levels. As with the Fukushima plant, other countries were affected by the radiation carried by the winds, however much of what was spread ended up at safe levels. It would also be the rate at which the radiation in the blast zone disappeared harmlessly also, making it habitable. So while a Neutron or Fusion blast would almost always have harmful radiation, at the point of creation, it is the containment of that radiation to the area initially affected that would make it "clean" to others. Is it possible to create a pure Fusion bomb with today's understanding? You point out that a reduction in physical size of bombs is a result of our understanding of how these things work; so a Fusion bomb could approach those yields of Fission without the historical sizes required? - that is why they went with Fission over Fusion, for the yield, right? Are you saying that blasts can be modelled by computers but the unknown reactions specific to areas cannot? what could be the worst case scenario regarding radiation from a pure Fusion blast? In the case of a Neutron bomb harmful radiation specifically passes through and coats objects, for a short time, while a Fusion bomb is much more geared toward the blast. But with the isotope issue are you saying that is something which would be carried by the winds or coat object in the blast radius? |
| Jun6-11, 10:46 PM | #16 |
| Jun11-11, 07:50 PM | #17 |
Recognitions:
There is actually a rather substantial difference between H-bombs and A-bombs. In fact, the H-bombs use an A-bomb as the "match" to light off the H-bomb part. Dr. Gregory Greenman |
| New Reply |
| Thread Tools | |
Similar Threads for: Radiation free blast?
| radiation from free electron with small acceleration | Quantum Physics | 18 | ||
| Doc Al!!!--Blast from the Past | Introductory Physics Homework | 3 | ||
| blast furnace? | Materials & Chemical Engineering | 1 | ||
| Blast from the past | General Discussion | 25 | ||
