Why Does My Calculation of Big Ben's Angular Momentum Keep Going Wrong?
The total angular momentum of Big Ben's hour and minute hands is calculated using the moment of inertia formulas for thin rods. The correct moment of inertia for the minute hand is Imin = 1/3 * 101 kg * (4.45 m)^2 = 665.51 kg m², and for the hour hand, Ihour = 1/3 * 61 kg * (2.65 m)^2 = 125.27 kg m². The angular velocities are ωmin = 2π/3600 rad/s and ωhour = 2π/86400 rad/s. The total angular momentum is Ltot = 4.13 kg m²/s, which differs from the initial incorrect calculation of 1.76 kg m²/s due to the use of the wrong moment of inertia formula.
  • Understanding of angular momentum and its calculation
  • Familiarity with the moment of inertia for thin rods
  • Knowledge of angular velocity and its units
  • Basic proficiency in physics equations and calculations
  • Study the derivation of the moment of inertia for various shapes
  • Learn about rotational dynamics and its applications in real-world scenarios
  • Explore the differences between calculating angular momentum for different axes of rotation
  • Investigate rounding errors and their impact on physics calculations
Students and professionals in physics, engineering, and mathematics who are interested in understanding angular momentum calculations and the principles of rotational motion.
Cyrad2
This is a problem that seemed easy to me. I keep recalculating the answer, and I keep getting it wrong. I'm not sure if I'm approaching the problem incorrectly, or if I'm just making some small dumb mistake. Here's the question:
Big Ben (see the figure below), the Parliament Building tower clock in London, has hour and minute hands with lengths of 2.65 m and 4.45 m and masses of 61.0 kg and 101 kg, respectively. Calculate the total angular momentum of these hands about the center point. Treat the hands as long, thin uniform rods.
Ltot = Lmin + Lhour
L=I*W
Irod = .5*m*L^2
Wmin = 2pi/3600
Whour = 2pi/86400
Lmin = .5(101)4.45^2 * 2pi/3600 = 1.745
Lhour = .5(61)2.65^2 * 2pi/86400 = .0156
Ltot = 1.745 + .0156 = 1.76
1.76 is what I keep getting. Any thoughts, comments, help would be greatly appreciated. Thanks in advance.
-Brad
Cyrad2 said:
Ltot = Lmin + Lhour
L=I*W
Irod = .5*m*L^2
Wmin = 2pi/3600
Whour = 2pi/86400
The rotational inertia of a thin rod about one end is [itex]I = 1/3 m L^2[/itex].
It's great that you have been working on this problem and have already calculated the total angular momentum. It's possible that you are making a small mistake in your calculations, but it's also important to make sure you are approaching the problem correctly.
First, let's review the formula for angular momentum: L = Iω, where I is the moment of inertia and ω is the angular velocity. In this case, we are dealing with two separate rods (the hour hand and the minute hand), so we need to calculate the moment of inertia for each rod separately.
As you correctly pointed out, the formula for the moment of inertia for a thin rod is I = 1/12 * m * L^2. However, this formula assumes that the rod is rotating about its center of mass. In this problem, the rods are rotating about a fixed point (the center of the clock), so we need to use a different formula for the moment of inertia.
The formula for the moment of inertia for a thin rod rotating about an axis at one end is I = 1/3 * m * L^2. Using this formula, we can calculate the moment of inertia for each rod:
Imin = 1/3 * 101 kg * (4.45 m)^2 = 665.51 kg m^2
Ihour = 1/3 * 61 kg * (2.65 m)^2 = 125.27 kg m^2
Now, we can calculate the angular velocity for each hand. The minute hand makes one full rotation every 3600 seconds (60 minutes), so its angular velocity is ωmin = 2π/3600 rad/s. The hour hand makes one full rotation every 86400 seconds (24 hours), so its angular velocity is ωhour = 2π/86400 rad/s.
Finally, we can calculate the total angular momentum:
Ltot = Lmin + Lhour = Imin * ωmin + Ihour * ωhour
= (665.51 kg m^2 * 2π/3600 rad/s) + (125.27 kg m^2 * 2π/86400 rad/s)
= 3.68 kg m^2/s + 0.45 kg m^2/s
= 4.13 kg m^2/s
This is slightly different from your calculated value, but it may be due to rounding errors
