Finding the charge on each capacitor
  • Thread starter Thread starter Femme_physics
    Capacitor Charge
The discussion revolves around a circuit with three capacitors connected to a 12V power source. The original poster seeks to find the total capacitance and the charge on each capacitor, given their individual capacitances.
  • The original poster attempts to find the charge on each capacitor using the relationship Q = VC but expresses uncertainty about applying Ohm's law in the context of capacitors. Some participants suggest that the total charge can be calculated using the total capacitance and voltage, while others confirm that the voltage across one capacitor in series is equal to the source voltage.
Participants are actively discussing the relationships between charge and voltage in capacitors, with some providing insights into the nature of series circuits. There is a recognition of the simplicity of the calculations involved, but no consensus has been reached on the final values of the charges.
Participants are navigating the constraints of the problem, including the need to understand the behavior of capacitors in series and the implications of the given voltage and capacitance values.
Femme_physics
http://img832.imageshack.us/img832/6442/cabalb.jpg
E = 12V
C1 = 8 [uF]
C2 = 6.571 [uF]
C3 = 6 [uF]
Find:
1) CT
2) Q1, Q2, Q3 on each of the capacitors.
http://img221.imageshack.us/img221/478/ctcap.jpg
CT was easy. I wasn't sure how to go about finding Q1, Q2 and Q3.
The idea I had was to simply find the voltage across each of them, but that means I have to ohm's law. But I can't use ohm's law with capacitors. If these were resistors I could. But, I don't have a formula that relates voltage, current and capacitance.
I only have Q = VC
Any clues?
Total charge extract from the cell is Q = C_T*E.
Across C2 potential difference is V = E.
so Q2= V*C2.
In series combination, charge are the same in each capacitor. Hence Q1 = Q3 = Q - Q2.
so Q2= V*C2.
Really? I wasn't sure if E=V in C2, but come to think about it it makes sense since the flow is uninterrupted.
So far so good. Simple enough. :)
A lot more simple than I would've first imagined. .
My thanks!
If you would like to more fully appreciate this concept, there is nice visual information here (last diagram on that page): http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capac.html" With your embedded image, you've inspired an interesting task to see if I can translate. How about this?
(Net 10) a. The following circuit which includes three capacitors, is connected to a power source E equal 12 Volts.
(Find):
1. The equivalent capacity of the circuit.
2. The electric charge Q1, Q2, Q3, located over each (capacitor) C1, C2, C3 - respectively.
  • · Replies 19 ·
9K
