| New Reply |
Can absence of hidden variables save locality? |
Share Thread | Thread Tools |
| May21-11, 01:58 AM | #52 |
Can absence of hidden variables save locality?Do you think a new field (higgs like) can function like a preferred frame? What are possible candidate of bonafide preferred frame? If an instantaneous signal can use it to commuinicate between say between 100 billion light years distance. Causality is not affected, isn't it. |
| May21-11, 02:29 AM | #53 |
No I don't haven't published any books, I meant "in my book" as in the idiom.
http://www.usingenglish.com/referenc...n+my+book.html in my book = in my opinion /Fredrik |
| May21-11, 03:05 AM | #54 |
| May21-11, 03:15 AM | #55 |
English isn't my native language either. I think your english appears very good to me though.
I see no need for a preferred frame of any kind. All there is are IMO interacting observerframes. The conventional view is that in such cases there are objective transformation rules that defines the observer invariants. But I object to that since this inference is done by an external observer. /Fredrik |
| May21-11, 09:03 AM | #56 |
After all it's simultaneous clicks in two detectors and as long as coincidence tend toward 100% matching as detectors tend toward 100% efficiency it does not affect the reasoning whether reason for clicks are beables or fairly localizable configuration of field. When you pair up different worlds you determine the past that should be already determined. From perspective of single world it is no different then FTL interaction. |
| May23-11, 04:36 AM | #57 |
The rest is easy. Let us assume QM and L. Consider the state |psi> = |up>|down> + |up>|down> before the measurement. Let the measurement reveal that the left particle is in the state |up>. Now from QM we know with certainty that the right particle is in the state |down>. Now consider an additional assumption that there is no H. This means that the new knowledge must also be described by a wave function, because there is nothing else at disposal (due to the no-H assumption). That means that now the total state must be |psi'> = |up>|down> However, the transition from |psi> to |psi'> is not local. On the other hand, L was an assumption. In other words, the additional no-H assumption led to a contradiction. Therefore, as QM and L are taken as assumptions, the no-H cannot be true. It must be false. Therefore, H must be true. Q.E.D. Note that this is not exactly the same reasoning as in the EPR paper, but is somewhat simplified in order to extract what I need. If your objection is: "Yes, but such a definition of H is not the one appropriate for the Bell theorem", then you are absolutely right. And that's exactly why the reasoning in the first post is not correct. You cannot consistently combine two different definitions of H and pretend that they are the same. |
| New Reply |
| Thread Tools | |
Similar Threads for: Can absence of hidden variables save locality?
| Can someone explain, simply, hidden nonlocality/locality? EPR Paradox? | Quantum Physics | 23 | ||
| Hidden variables | Advanced Physics Homework | 0 | ||
| Hidden Variables | Quantum Physics | 9 | ||
| QM hidden variables | Quantum Physics | 46 | ||
