Do these 3D vectors intersect at the given points?
  • Context: Undergrad
  • Thread starter Thread starter paulfr
    3d Vector
The discussion centers on the intersection of two 3D lines represented by the parametric equations: x = 1 + 2t, y = 2 – t, z = t and x = -2 – s, y = 3 + 3s, z = 1 + 4s. The calculated parameters t = -8/5 and s = 1/5 yield inconsistent z-values, indicating that the lines do not intersect. The system of equations derived from setting the x, y, and z values equal results in an inconsistent system, confirming that the lines are skew. The user questions the accuracy of the input into WolframAlpha, but the consensus is that the lines do not intersect.
  • Understanding of parametric equations in 3D space
  • Familiarity with systems of equations
  • Knowledge of matrix methods for solving equations
  • Experience using computational tools like WolframAlpha
  • Study the concept of skew lines in 3D geometry
  • Learn how to solve systems of equations using matrix methods
  • Explore the functionality of WolframAlpha for solving parametric equations
  • Investigate the implications of inconsistent systems in linear algebra
Mathematicians, physics students, engineers, and anyone involved in 3D modeling or computational geometry who needs to understand line intersections in three-dimensional space.
paulfr
If I put these 2 lines into wolframalpha.com it comes up with a solution
x = 1 + 2t , y = 2 – t , z = t ; x = -2 – s , y = 3 + 3s , z = 1 + 4s
t = -8/5 and s = 1/5 using equations for x & y
Solution; x = -11/5 y = 18/5 z = 9/5But the z values do not match so how can these lines intersect ?
Thanks for your input
Setting the x, y, and z values equal, you get the system of equations
1 + 2t = -2 - s
2 - t = 3 + 3s
t = 1 + 4s
Moving the variables to one side gives this system
s + 2t = -3
3s + t = -1
4s - t = -1
Using matrix methods, this turns out to be an inconsistent system, meaning that the two lines don't intersect. Are you sure that the equations you entered into wolframalpha are the same as you posted?
Yes I checked the data several times
Wolframalpha's solution seems to ignore that z=t which
gives a different value than the 9/5 from z=1+4s
Perhaps there is some subtle interpretation they are making ?
The lines appear skew to me
Thanks for the comments
  • · Replies 20 ·
