| New Reply |
Is radial acceleration and centripetal acceleration the same thing? |
Share Thread |
| May24-11, 05:54 AM | #1 |
In uniform circular motion,
Is radial acceleration and centripetal acceleration the same thing? Just a vector pointing towards the center? i.e. a synonym? |
| May24-11, 06:32 AM | #2 |
Mentor
Yes. Typically those terms are synonymous in that context.
| May24-11, 07:05 AM | #3 |
| May24-11, 07:13 AM | #4 |
Mentor
Those formulas are essentially the same. For whatever reason, the second formula uses n for the frequency. (Think n = number of cycles per second.)
| May24-11, 07:15 AM | #5 |
I see it now :) Thanks Doc.
| May24-11, 08:29 AM | #6 |
I understand that V is tangential speed, and that acceleration is centripetal acceleration. But is there also a beast known as tangential acceleration? I thought the only two players here are the two mentioned first.
| May24-11, 08:45 AM | #7 |
Recognitions:
Same thing for acceleration - it has a tangential and a radial component. The case of circular movement is special in that the acceleration only has a radial (or centripetal) component. Furthermore, the speed only has a tangential component. |
| May24-11, 08:49 AM | #8 |
Mentor
| May24-11, 08:53 AM | #9 |
Hi Femme_physics!
![]() See also http://en.wikipedia.org/wiki/Polar_c...ector_calculus ![]() (oh, and centripetal acceleration is minus radial acceleration) |
| May24-11, 10:19 AM | #10 |
Recognitions:
The accelerations are the same: [tex]\vec{F_c}/m = -\omega^2r \hat{r} = \ddot{\vec{r}}[/tex] AM |
| May24-11, 10:41 AM | #11 |
![]() (not enough {} )Yes … eg a centripetal acceleration of 5 m/s2 would be a radial acceleration of -5 m/s2
| May24-11, 02:00 PM | #12 |
I can see clearly now :) Tangential acceleration only occurs when there's a force applied. Thanks tiny-tim, ILS, Doc, Andrew. Being in mechanics class for the past 4 hours also helped!
| New Reply |
Similar discussions for: Is radial acceleration and centripetal acceleration the same thing?
| Confused by radial vs. centripetal acceleration | Classical Physics | 3 | ||
| Tangental acceleration from given centripetal acceleration and a range of radii | General Physics | 2 | ||
| Confused about Centripetal and Radial Acceleration | Introductory Physics Homework | 1 | ||
| Centripetal Acceleration and Tangential Acceleration problem driving me crazy! | Introductory Physics Homework | 1 | ||
| Centripetal acceleration, incorporating a change in acceleration around the circle... | Introductory Physics Homework | 3 | ||
