Understanding Notation for Integration in Tempered Alpha Stable Distributions
  • Context: Graduate
  • Thread starter Thread starter cernlife
    Integration
The notation \(\int_{R^d}\) indicates integration over the entire real space, specifically \(\int_{-\infty}^{\infty}\) when \(d=1\). The discussion centers on the Levy measure \(M\) of a tempered alpha stable distribution, as outlined in Rosinski's paper "Tempering Stable Processes." The theorem presented states that \(M(A) = \int_{R^d}\int_0^{\infty} \textbf{I}_A(tx)t^{-\alpha-1}e^{-t}dtR(dx)\). The user is attempting to derive the function \(R(dx)\) by differentiating both sides of the equation involving the Gamma function kernel, \(\Gamma(-\alpha)\).
  • Understanding of tempered alpha stable distributions
  • Familiarity with Levy measures and their properties
  • Knowledge of the Gamma function and its applications
  • Basic concepts of integration in multiple dimensions
  • Research the properties of tempered alpha stable distributions
  • Study the derivation and applications of Levy measures
  • Learn about the Gamma function and its integral representations
  • Explore techniques for differentiating integrals with respect to parameters
Mathematicians, statisticians, and researchers in stochastic processes who are working with tempered alpha stable distributions and need to understand the intricacies of their notation and properties.
cernlife
I'm reading this journal article and they keep on using the notation
[tex]\int_{R^d}[/tex]
What does this mean, just say d=1, does it then mean
[tex]\int_0^{\infty}[/tex]
or
[tex]\int_{-\infty}^{\infty}[/tex]
any help much appreciated.
It means the second one, but you have to take into account the support of whatever you're integrating, but if the support is over all of R then the integral will be over all of R as well.
I am trying to find a function R(dx) in a paper by Rosinski "Tempering Stable Processes" which has the following theorem
Theorem 2.3. The Levy measure M of a tempered alpha stable distribution can be written in the form
[tex]M(A) = \int_{R^d}\int_0^{\infty} \textbf{I}_A(tx)t^{-\alpha-1}e^{-t}dtR(dx)[/tex]
where I_A(tx) I assume is the indicator funtion, i.e. tx is defined on the interval A
now I'm using definition of the Gamma function kernal to say
[tex]\int_0^{\infty} t^{-\alpha-1}e^{-t}dt = \Gamma(-\alpha)[/tex]
I know the Levy measure M, and so putting that in for M, I then had
[tex]2^{\alpha}\delta\frac{\alpha}{\Gamma(1-\alpha)}x^{-1-\alpha}e^{-0.5\gamma^{1/\alpha}x} = \Gamma(-\alpha)\int_{R^d}R(dx)[/tex]
So I need to work out what the function R(dx) is, which is my problem. I was thinking I could just differentiate both sides which would get the integral out of the right hand side and then I could easily rearrange to find R(dx). However I am not sure about this method as I have this integral over the range R^d.
How do I work out what R(dx) is?
  • · Replies 16 ·
