Troubleshooting Electric Field Calculation: Qs, Rs, and N/C
The forum discussion centers on calculating the electric field at a midpoint between two charges, specifically a -8.0 µC and a +6.0 µC charge, located 4 cm apart. The initial calculation incorrectly omitted squaring the distance for one of the charges, leading to an erroneous result of 6,300,000 N/C. The correct approach involves applying Coulomb's law and the superposition principle to compute the electric fields due to each charge separately and then summing them to find the net electric field.
  • Coulomb's Law for electric fields
  • Understanding of electric charge units (microcoulombs)
  • Concept of superposition principle in electric fields
  • Basic knowledge of vector addition in physics
  • Review Coulomb's Law and its application in electric field calculations
  • Study the superposition principle in electrostatics
  • Learn about vector addition and its relevance in physics problems
  • Practice electric field calculations with varying charge configurations
Students studying electrostatics, physics educators, and anyone looking to deepen their understanding of electric field calculations and principles.
joej
I'm doing the following problem, it seems to me that I am doing all the correct steps but my answer differs from the answer key, am I missing something?
1. What is the magnitude and the direction of the electric field at a point midway in between a -8.0uC and a +6.0uC change 4cm apart.
This is what I'm doing:
E = ( k * (Q1 / r1^2) ) * ( 1 + ( (Q2 / Q1) / (r2^2 / r1^2) ) )
(9x10^9 * ( (8 * 10^-6) / ( 2 * 10^-2) ) ) * ( 1 + ( (6 / 8) / (2 / 2) ) )
3600000 * 1.75 = 6300000 N/C
now... that is what I'm getting, could somoen please point out to me what I am forgetting to do, if anything.
__________edit
stupidity strikes again... forgot to square r1
Why write E in such a strange way? (to me anyway)
Use Coulomb's law and the superposition principle.
Calculate the field due to Q1 and the field due to Q2, then add.
Hello joej...
The formula for electric field at a point distant r units from a charge Q is:
[tex]\vec{E} = \frac{1}{4\pi\epsilon_{0}}\frac{Q}{r^2}\hat{e}_{r}[/tex]
The direction of the field is radial. In your problem you need to compute
[tex]\vec{E}_{net} = \vec{E_{1}} + \vec{E_{2}}[/tex]
the two terms arising due to the electric fields produced (independently--make a note of this, the superposition principle) has been used here) by the two charges. Have you used this fact? :confused:
Cheers
Vivek
  • · Replies 16 ·
