Gravitomagnetic Force: Uncovering the Mystery
  • Context: Graduate
  • Thread starter Thread starter Jonny_trigonometry
    Force
The discussion revolves around the concept of "gravitomagnetic" force and its potential implications in unifying electromagnetism with gravity and other fundamental forces. Participants explore theoretical connections, implications for cosmic phenomena, and the nature of forces in the universe, including the possibility of anti-gravity effects and the behavior of light in varying energy densities.
  • Some participants propose that the similarities between gravitational and electromagnetic equations suggest a deeper connection between charge and mass, possibly in higher dimensions.
  • Others argue that the "gravitomagnetic" force could explain phenomena such as the behavior of black holes with spinning accretion disks and the acceleration of cosmic expansion.
  • One participant mentions the Lense-Thirring effect as an example of gravitomagnetic influence, noting its detection through satellite measurements.
  • There are questions regarding the nature of magnetic fields and why not all charges exhibit them, with references to various big bang theories and the expansion of the universe.
  • Some participants express skepticism about the validity of the "gravitomagnetic" force and related concepts, labeling them as unsubstantiated.
  • Discussions include the potential for anti-gravity phenomena and the role of plasma in understanding the essence of matter, with references to various resources for further exploration.
  • Questions are raised about the speed of light and its potential variability based on energy density, suggesting a need for experimental validation.
Participants express a range of views, with no clear consensus on the validity of the "gravitomagnetic" force or its implications. Some support the idea while others challenge its credibility, indicating ongoing debate and uncertainty.
Limitations include unresolved assumptions about the nature of forces, the definitions of terms like "gravitomagnetic," and the implications of various theories discussed. The discussion also reflects differing interpretations of experimental evidence and theoretical frameworks.
This discussion may be of interest to those exploring theoretical physics, cosmology, and the interplay between gravity and electromagnetism, as well as individuals curious about advanced concepts in plasma physics and potential applications in anti-gravity research.
Jonny_trigonometry
This whole "gravitomagnetic" force that I've read about, does it hold water? Is this a way to combine electro-magnetism with matter-energy? The equations are so similar that I wondered this myself... what if charge and mass are closely linked, maybe in a higher dimension? electric fields resemble gravtiational fields (that is if anti-matter is used as the negative charge candidate). The presence of magnetic fields around moving charges suggests that maybe matter has a similar property when it is in motion. Perhaps (since parallel moving charges attract each other), gravity as we know it is just the force felt due to the equavilent magnetic type field (of parallel moving masses) and strength is due to speed and amount of mass. I realize the gravitomagnetic force is defined as a field caused by the spin of matter rather than the speed of matter, but doesn't this suposed force help explain why black holes with a spinning accretion disk don't suck in matter-energy on the axis of it's poles? also, doesn't it help explain the acceleration of cosmic expansion? that is, if this force exists, then might it be enough to add an overall higher velocity to all matter in the universe over time?
follow up quesions: How do you define zero velocity with relativity theory?
why don't all charges have magnetic fields if all matter is moving away from the center of mass of the universe (where the big bang took place)? Can the ratio of Epsilon_0 and Mu_0 change? Can the speed of light change according to the difference in energy-density of the space through which the light traverses and the energy-density of the space where the light is observed? yes I know, more incoherent thoughts...
Well, actually it is when all the forces unite, gravity, weak, strong, and EM, into one. Like EM and the weak have already been proven, at a high enough temperature, to unite into a single "electroweak" force.
Kenneth W. Ford said:
In some sense, then the weak and electromagnetic interactions are one and the same force. not quite, however, for the weak interaction is universal, affecting particles of all kinds. The electromagnetic interaction affects only particles with electric charge.
Well, the EM is 1039 (1,000,000,000,000,000,000,000,000,000,000,000,000,000) times stronger than the gravitational force. That's a whole lot.
Well, there are several big bang theories, and not all of them say everything came from a point in the universe, and no one knows if the universe is expanding or compressing, though it looks as if it is currently expanding. The big bang, is also only one of many widely accepted theories.
Hi,
The possibllity of gravito-magnetic and gravito-electric forces are the basis behind some work being done today on possible anti-gravity phenomena.
See
http://www.americanantigravity.com/
juju
What a collection of hoohah.
Interestingly, the Lense-Thirring effect is the precession
of the orbital plane of an object moving in the gravitomagnetic
field of a spinning central object. I have read it in this paper
http://arxiv.org/abs/gr-qc/0407116
Although relativity defines gravity as a curve, it is possible that it is a 'pressure' difference causing a force caused by the diffusion of space. That is my idea. Proof would be in finding out if light does change speeds traveling through different 'energy-densities' (or gravity strength values). This would mean measuring the speed of photons at three different points in space, then measuring the differences of the time displacement at those points. You would then have to account for the speed of the light within those points relative to the control.
This would be the only way you could be able to find the answer to your question. Unless someone has another idea.
juju said:
Hi,
See
juju
All i see is using an electric corona to create an ionic air flow that pushes down. Is there any proof of this idea working in a vacum?
Yes indeed, otherwise known as frame dragging. It was just detected by pinging satellites with lasers over a period of about a decade. And they find the Earth's rotation produces a precession on the satellites of a few inches a year. You are not going to be able to go to the stars on that, but it is important because it does funny things to the physics near a black hole.
i think what would help you a lot is a better understanding of Plasma and Cosmic Plasma.
did you know that plasma is considered the First of Four states of matter with gas,liquid, solid following in that order.
also because gas,liquid,solid are charge or electrically neutral there is NO energy coming from these states. however from plasma ALL wave lengths are present,therefore this is the place where all matter comes from,and as the plasma cools this is when particles appear.
now is this fascinating, ABSOLUTELY. i mean this the study of the essence of matter, Cosmic Plasma(plasma's period really) also involves magnetics,electric currents and so much more BUT right up your ally. once you see for yourself you'll never look back. any Natural Philosophy,inquiry without plasma's involved is automatically incomplete and therefore invalid.
a couple of sites are;www.theuniverse.ws[/url] and [url]www.plasmas.org[/URL]
enjoy!
Without the air all we are doing is creating another way to fly, but only in our atmosphere. Please give me a way to counteract gravity in a vacuum. Otherwise we do not have antigravity.
  • · Replies 20 ·
