Register to reply
Shortest Distance between 2 skew lines (vectors)
by thomas49th
Tags: distance, lines, shortest, skew, vectors
Share this thread:
thomas49th
#1
Jun1-11, 02:12 PM
P: 656
x1 = (0,0,4) + s(2,0,-1)
x2 = (-4,2,2) + t(-5,1,1)
2. Relevant equations
3. The attempt at a solution
First of all I find the common perpendicular (vector cross product)
Make it unit
Find a arbitrary line joining the two 2 lines (set s = t= 0)
Then scalar produce the unit normal and the line between the vectors to get the minimum distance. I get 2/sqrt(14), while the answers say just sqrt(14). How so?
Also I am just doing the method, but what does it mean geometrically. Why find a line perpendicular, or use a unit vector?
Thanks
Thomas
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
HallsofIvy
#2
Jun1-11, 02:32 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,353
The shortest distance from a point to a line is always along the line perpendicular to the given line. That is because the hypotenuse of a right triangle is longer than either leg.
As a result of that, the shortest distance between two skew lines is along the line perpendicular to both given lines.
Ray Vickson
#3
Jun1-11, 02:32 PM
Sci Advisor
HW Helper
Thanks
P: 4,959
Quote Quote by thomas49th View Post
Make it unit
Thanks
Thomas
I did it another way: I expressed the distance^2 between x1 and x2 as a function of s and t, then minimized it. My distance answer agrees with yours.
RGV
thomas49th
#4
Jun1-11, 02:39 PM
P: 656
Quote Quote by HallsofIvy View Post
I know that the shortest distance between 2 skew lines is perpendicular, but why does finding the "common perpendicular" help. Let's go to a 2D graph. Let there be 2 parallel lines (2D equiv of skew lines). Taking the vector product produces a vector into or out of the graph (from our view on a 2D graph you cannot see the vector because it goes "into" or "out of" the graph).
How does finding this vector help. For that matter, how does finding an arbitray line between the 2 vectors help
Thanks
Thomas
thomas49th
#5
Jun1-11, 02:45 PM
P: 656
Quote Quote by Ray Vickson View Post
RGV
That's how the problem sheet answer is done (I don't like doing it that way... I DON'T understand why you square it) but they get sqrt(14). I get 2/sqrt(7) or sqrt(7/2) . Hmm.
Quinzio
#6
Jun1-11, 03:00 PM
P: 558
Your answer is correct.
Geometrically meaning: imagine the 2 parallel planes that each contains one of the lines.
Easier: imagine 2 parallel planes and on each plane draw one line.
Connect the 2 lines by a 3rd line AB. In A draw the perpendicular of the 2 planes.
The length of the perpendicular is the projection of AB onto the perpendicular of the planes in A (or B, the same).
Ray Vickson
#7
Jun1-11, 06:58 PM
Sci Advisor
HW Helper
Thanks
P: 4,959
Minimizing d(s,t)^2 gives the same solution as minimizing d(s,t). What could be simpler?
RGV
thomas49th
#8
Jun1-11, 07:24 PM
P: 656
why would you want to minimize d(s,t)^2 and not d(s,t). am I missing something stupidly ovbious?
SammyS
#9
Jun1-11, 11:24 PM
Emeritus
Sci Advisor
HW Helper
PF Gold
P: 7,801
why would you want to minimize d(s,t)^2 and not d(s,t). am I missing something stupidly obvious?
The square of the distance does not have square roots, so it's much easier to work with.
Register to reply
Related Discussions
Perpendicular distance between two skew lines? Precalculus Mathematics Homework 1
Calculate point off shortest distance between two skew lines Differential Geometry 0
Shortest distance between two skew lines Calculus & Beyond Homework 2
Find the shortest distance between 2 non-paralle lines (skew lines) in 3-space Calculus 4
