| New Reply |
how do you find the moment of inertia for wierdly shaped objects? |
Share Thread |
| Jun1-11, 08:17 PM | #18 |
http://www.livephysics.com/tables-of...f-inertia.html
the rectangular plate equation on that page is (1/12)*Mass*(a^2+b^2) where a and b are the lenght and width but this equation is if the axis is through the center. if the axis is at one end like my boomerang, would i just substitute (1/12) with (1/3)? |
| Jun1-11, 09:42 PM | #19 |
| Jun1-11, 09:43 PM | #20 |
Recognitions:
| Jun1-11, 09:57 PM | #21 |
| Jun1-11, 10:14 PM | #22 |
Recognitions:
The parallel axis theorem states, in essence, that given a known moment of inertia I about some axis, then if you move the axis of rotation some distance r from that axis, being sure that the new axis is parallel to the old axis, then the moment of inertia about that new axis is given by Inew = I + M*r2. M is the mass of the object. The formula that you found for the moment of inertia for the plate about its center should be 'shifted' by adding M*r2 to it, where r is the distance from the center of the plate to the actual axis of rotation. |
| Jun1-11, 10:24 PM | #23 |
thank you. I understand it so much better now. And you were right, it is about 5.4 cm between the center of rotation and the center of the plate. I simply misread what you wrote.
| New Reply |
| Tags |
| boomerang, cardboard, equation, inertia, moment of inertia |
Similar discussions for: how do you find the moment of inertia for wierdly shaped objects?
| moment of inertia of a wire shaped into a semi circle | Introductory Physics Homework | 1 | ||
| moment of inertia for T shaped object | Introductory Physics Homework | 4 | ||
| Moment of Inertia of a butterfly-shaped yoyo | Introductory Physics Homework | 3 | ||
| Moment of Inertia - Hollow Objects | Introductory Physics Homework | 1 | ||
| Moment of Inertia of L-shaped bar | Advanced Physics Homework | 4 | ||
