Conserving contiguity with a transposed progression
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
The discussion revolves around the possibility of rearranging a sequence of integers from 1 to N such that no two adjacent integers in the new arrangement retain their original adjacency. The scope includes theoretical exploration and mathematical reasoning regarding the conditions under which such rearrangements can or cannot occur.
  • Exploratory, Mathematical reasoning, Debate/contested
  • One participant questions whether a sequence can be rearranged without retaining original adjacency.
  • Another participant suggests a specific rearrangement for a small value of N, proposing the sequence 1,3,5,2,4,6.
  • A participant inquires if the proposed rearrangement holds for any N.
  • It is noted that for N <= 3, it is impossible to achieve the desired rearrangement.
  • For N >= 5, a participant claims that listing the odd numbers followed by the even numbers suffices for the rearrangement.
  • The case of N=4 is discussed in detail, with a participant providing reasoning that shows it is not possible to rearrange the sequence without retaining adjacency when considering endpoints as neighbors.
  • Specific challenges are raised regarding starting points for the sequence and their implications on adjacency, indicating that wrap-around conditions complicate the arrangement for N=4.
Participants generally agree that for N <= 3 and N=4, it is not possible to rearrange the sequence as required. However, for N >= 5, there is a proposal that it can be done, indicating a lack of consensus on the broader applicability of the rearrangement method.
The discussion highlights limitations in the reasoning for specific values of N and the implications of considering endpoints as neighbors, which remain unresolved.
Loren Booda
Can a sequence of integers from 1 to N be rearranged so that no two neighbors retain their original adjacency?
I suppose running it backwards (6,5,4,3,2,1) is not enough for what you meant.
Then, how about 1,3,5,2,4,6.
And for any N?
Well, for N <= 3 you obviously can't, so the trivial response is "no".
For N >= 5 you only need to list the odds, then the evens.
The interesting case is N=4. If you don't count the endpoints, 2,4,1,3 suffices. If you count them as neighbors, then
- Sequences starting with "1" won't have a place for "2": second and fourth are neighbors to "1", and third place would make it neighbor to wherever you place "3".
- Similar for sequences starting with "4": there's no place for "3" (third place leaves no place for "2").
- Similar when starting with "2", where there is no place for "3" (second and fourth are neighbors to "2", third would leave no place for "4").
- And same for starting with "3", where similarly there is no place for "2" (third place leaves no place for "1").
So with wrap-around, N=4 is a no-no.
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 17 ·
